It is possible to configure Shoretel DHCP option 156 on a Cisco Sx300 & Sx500 SMB Switch. However the configuration is subtly different from Cisco IOS classic configuration. For example below (on Cisco classic):
option 156 ascii "configservers=172.16.1.7, ftpservers=172.16.1.7, country=7, language=4, layer2tagging=1, vlanid=2"
PLEASE NOTE: Custom options are supported from 1.3.5.x on the Sx300 & Sx500 Series
- Updated DHCP Server to add support for user-defined options for Sx300 and Sx500
Here's what happens if you try to add ASCII strings to Option 156 on Cisco SMB Switches.
Input:
ip dhcp pool network 172.16.1.0
Output:
switch4221e7(config-dhcp)#$7, language=4, layer2tagging=1, vlanid=2"
DHCP server option parameters mismatch. This code 156 must be from other type.
Solution:
Simply convert the DHCP Option 156 ASCII data to HEX and all works perfectly! The Sx300 will not accept ASCII format although it has the option in CLI.
Here's an example for Voice VLAN 2. (Data on VLAN 1)
Switch Config: (Important sections only)
vlan database
vlan 2
exit
ip dhcp server
ip dhcp pool network Data
address low 172.16.1.11 high 172.16.1.100 255.255.255.0
default-router 172.16.1.6
option 156 hex 667470736572766572733d3137322e31362e322e372c20636f756e7472793d372c206c616e67756167653d342c206c617965723274616767696e673d312c20766c616e69643d32 description Shoretel
exit
ip dhcp pool network Voice
address low 172.16.2.11 high 172.16.2.100 255.255.255.0
default-router 172.16.2.6
interface vlan 1
ip address 172.16.1.6 255.255.255.0
no ip address dhcp
interface vlan 2
name Voice
ip address 172.16.2.6 255.255.255.0
interface fastethernet1
switchport trunk allowed vlan add 2
interface fastethernet2
The same theory should apply to other custom options on Sx300 & Sx500 Series switches.
Hope it helps
Matt
This document was generated from the following discussion: Will a Cisco SMB SG300 Switch support DHCP Option 156?
