Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
How to map and identify different inbound calls to different companies under the same UC500
2267
Sometimes, the same UC500 and IP phone user site may serve different companies. It is therefore important, to be able to identify the inbound call based on the called number. There are several ways to do this:
1) Configure directory entries (under telephony service) for the DIDs and associate the entries with appropriate company name. In addition to this, the "service dnis dir-lookup" needs to be enabled under the telephony-service. Please note that this command is enabled in the default configuration files for UC500, so the only thing that is needed, is create directory entries.
2) Have each inbound number ring on different line buttons of the IP phone. This would give a quick visual indication of which company is being called, and each button can also be labeled with the appropriate company name. The idea is the to segregate the dialplan. See below:
- Create new Class of Restriction lists:
dial-peer cor custom
name IncomingRuleA
name IncomingRuleB
dial-peer cor list CompanyA
member IncomingRuleA
dial-peer cor list CompanyB
member IncomingRuleB
- Create POTS dial peers like these:
dial-peer voice 1 pots
incoming called-number AAAAA
direct-inward-dial
corlist incoming CompanyA
dial-peer voice 2 pots
incoming called-number BBBBB
direct-inward-dial
corlist incoming CompanyB
- Create Ephone DN’s like these:
ephone-dn 21 octo-line
number 1111
label Company A
corlist outgoing CompanyA
ephone-dn 22 octo-line
number 2222
label Company B
corlist outgoing CompanyB
- Assign to the phones like this:
ephone 5
button 1:21 2:22
3) If using FXO (no DID support), the following can be done:
- Organize the FXO POTS dial peers in groups
- Assign each corlist to each dial peer PAIR. Example:
dial-peer voice 50 pots
destination-pattern 9.T
voice-port 0/1/0
connection plar opx 201
dial-peer voice 51 pots
voice-port 0/1/1
dial-peer voice 52 pots
voice-port 0/1/2
connection plar opx 202
dial-peer voice 53 pots
voice-port 0/1/3
- Assign a corlist to an octal ephone DN that is a shared line across phones. Something like this:
number 201
ephone 5
button 1:21
ephone 6
button 1:21
number 202
ephone 7
button 1:22
ephone 8
button 1:22
The idea is to segregate the dialplan. An incoming call on one of the FXO ports will trigger a connection plar to an octo dn that is part of that CORLIST ONLY. That octo DN will be shared by all phones in that group. If there is phone overlap (one phone belongs to more than one group) then you can map the octo DN to a different button on the same IP phone. That way, the user can visually differentiate calls between company A and company B.
Notice that the global commands to define the corlist members are not included here (previous example had instructions on how to add them).
Also, you may have many more POTS dial peers because of your dialplan. You will need to group them accordingly and map a corlist to each group.
Derek Thom
Beginner
Thanks for posting the different methods for accomplishing this. I have a billing company that will need to have this configured, as each employee has several companies assigned to them, and the user must answer the phone as though they are representing that company.
I do have a couple of questions:
Referring to method 2, would this allow a different voicemail box for each company represented by a button on a single phone? Also, would this use up a license per company?
Thanks!
Derek
