NSS322 Smart Storage Tips for OnPlus
548
Portal Feature
Constraints/Notes
Discovery
Discovery of the NSS 300 Series device depends on Bonjour discovery. The NSS 300 should have Bonjour advertisements enabled for both Web Administration and CSCO-SB.
Device Access and Information
Administration of the NSS 300 series NAS is done via the Web interface. Firmware versions 1.1, 1.2, and 1.3 are currently supported.
•    If available, administration is done using HTTPS on port 443.
•    If this port is not available, administration is done via HTTP on
port 8080.
•    If neither of these ports are open, the device will not be manageable.
Configuration Backup and Restore
Backup and restore of the NAS300 is performed using the backup and restore functions of the Web interface, and works exactly as if the user was performing those functions using the conventional administrative interface.
A configuration restore requires a reboot, and NAS reboots can vary in time, depending on the amount of storage management that has to take place.
•    If the reboot time lasts longer than five minutes, the OnPlus Agent may report that it failed to reconnect to the device.
•    If the device gets a new IP address during reboot, the OnPlus Agent will try to reconnect at the new address, but this process is not completely reliable. Giving managed devices a fixed IP address is recommended.
Firmware Upgrade
Updating firmware on NAS300 is performed using the Web interface, and works exactly as if the user was performing those functions using the conventional administrative interface.
A firwmare update requires a reboot, and NAS reboots can vary in time, depending on the amount of storage management that has to take place.
- If the reboot time lasts longer than five minutes, the OnPlus Agent may report that it failed to reconnect to the device.
- If the device gets a new IP address during reboot, the OnPlus Agent will try to reconnect at the new address, but this process is not completely reliable. Giving managed devices fixed addresses is recommended.
