Autoattendant and Teleworker Technical Overview SBCS Monthly Webcast
Overview of Stonevoice for Cisco SBCS Stonevoice for Cisco SBCS
Cisco Supportwiki Overview Supportwiki Partner Overview
There are 5 AA systems supported, so you can call between 5 different AA.
For IP phone directory the order is configurable, default is last name, first name. For AA, it depends on the script variable I believe (not sure if this is for the default scripts that Saurabh has).
The AA_SBCS scripts are bundled in the UC500 4.2.7 software pack
The Cisco Supportwiki, accessible at http://supportwiki.cisco.com/sbcs
The Cisco Supportwiki, FAQs have samples for commonly used configurations. An example of a FAQ would be: http://supportwiki.cisco.com/wiki/index.php/SBCS:Voicemail_-_Cisco_Unified_Communications_500_Series_-_Cisco_Smart_Business_Communication_Systems#FAQ
No, in CUE 3.0 the total prompt capacity for NME-CUE is 250 minutes, but each individual prompt has no maximum as long as total capacity is not exceeded. More details are available on Release Notes for Cisco Unity Express 3.0
Yes, Direct Xfer to mailbox is supported. Please see: http://supportwiki.cisco.com/wiki/index.php/SBCS:Voicemail_-_Cisco_Unified_Communications_500_Series_-_Cisco_Smart_Business_Communication_Systems#Is_direct_transfer_to_mailbox_feature_supported.3F_If_so.2C_how_can_this_be_configured.3F
Auto Attendant option is located under Voicemail > Auto Attendant
Yes Direct Xfer to mailbox is supported http://supportwiki.cisco.com/wiki/index.php/SBCS:Voicemail_-_Cisco_Unified_Communications_500_Series_-_Cisco_Smart_Business_Communication_Systems#Is_direct_transfer_to_mailbox_feature_supported.3F_If_so.2C_how_can_this_be_configured.3F
Yes – the AA_SBCS scripts in UC500 software pack has a checkbox I believe to enable or disable this.
Using CCA you can ring all the phones, but cannot forward unanswered calls to AA (yet), but it is a roadmap item for CCA. Forwarding of unanswered calls to the AA can be done by using CUE GUI.
There is a Administration guide for CUE GUI posted below: http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel3_0/administration/guide/gui/gui30.html
You would type in the AA pilot number(s) in the tranfer options
Today we support 3 options: - Longest Idle - Peer - Sequential
in hunt groups
CCA derives the username information from CME under the ephone, so changing it in CUE GUI won’t reflect changes in CCA. For the AA scripts supported by CCA, if you change the parameter, it will get detected by CCA. But if a script is not supported in CCA, then this won’t get updated
SIP trunks support this under the dialpeers based on provider requirements.
Yes
Yes
The functionality of the GUI interfaces such as CCA will continue to improve. The flows you are currently asking for are supported by creating a custom script using the cue script editor. For assistance on custom scripts, please e-mail ask-cue-editor@external.cisco.com
G.729 codec on SIP trunks is supported today on the UC500. Separate licenses are not required for using G.729 codec.
For over five users at a remote site, available bandwidth becomes an issue. As such for PSTN access at a 5+ users site, local PSTN access and distributed call processing become requirements. For 5+ user sites, the recommendation is to use an UC500 at the remote site and interconnect the sites using SIP or H.323 trunks.
ASA does not do the QoS that’s supported on 871 IOS router.
Cisco 871 Integrated Services Router
Cisco 851 has not been tested with the UC500. Since CCA does not support the 851 the provisioning will need to be done entirely on the CLI or other GUI tools such as Cisco SDM.
For remote teleworkers – on 8/16 its 80Kbps and for 24/32/48 user SKUs its 26Kbps
You can use Dynamic DNS to terminate VPN connection on dynamic IP addresses
Yes, using CLI and need Transcoding (hence only supported on the 24 / 32/ 48 user SKUs) http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmebasic.html#wp1061320
Yes, CME license is required, which is available as add-on or bundle
Please see Lab 3 for First Look ftp://ftpeng.cisco.com/sbcs/doc/UC500-CCA-First-Look-v1-Lab3.pdf
Cisco offers SIP based 3911 phones. 3rd party SIP phones may work, but are not supported by Cisco TAC. Customer will need to contact the 3rd party SIP phones technical support for any issues related to 3rd party SIP phones.
For MultiSite UC500 deployments, you can configure a remote site to use main site’s FXO lines. You will need to configure appropriate dialplan for this on both sites.
SIP Trunking is supported natively on the UC520
Voice traffic between 871 and UC500 is encrypted over VPN tunnel, so voice traffic cannot be sniffed by other parties on the internet. When the QoS is configured on 871s, the 871 will ensure that voice packets get higher precedence than data packets, but this needs to be ensured on each and every hop. Internet based broadband don’t honor QoS. So there won’t be any guarantee that the voice traffic would be given a preferential treatment.
Please contact Stonevoice (tarun.kapoor@stonevoice.com) directly for SkyStone queries
Each software pack has a readme file that contains the latest soft
The Supportwiki differs from Cisco Forums in that it is designed to provide content, such as Vods and trainings, which is more than can be delivered in the Q&A format of Cisco Forums such as Netpro. The Supportwiki will be expanded to include Cisco solutions outside of SBCS.
=== With VPN from remote client to UC500, all calls from remote site to main site are encrypted, so how do you apply QoS to voice calls ? The TOS byte of the IP header is pre-examined and packets are given higher precedence based on the TOS byte ===
=== Is there a recording tool that is recommended for creating WAV files for upload to CUE AA/ What is the particular file format for saving (ie ulaw) Please see [Lab 3 for First Look] === ftp://ftpeng.cisco.com/sbcs/doc/UC500-CCA-First-Look-v1-Lab3.pdf
ArcExpress 2.0 will be supported with CME and UC500.
Not yet – this is possible later this year
This can’t be done today, but is a roadmap item on one of the upcoming releases of CCA.
Correct. Beyond 30 days, partners must purchase service contracts to be able to download software upgrades.
CCA is constantly being enhanced to add additional functionality. Enhancements are on the roadmap to allow custom configs to coexist with CCA. CCA currently supports the ability to provision call park. Upcoming feature enhancement will also allow call park slots to be configured as monitor buttons.
In CCA, you can provide feedback by selecting Help > Feedback
Yes – this is on the roadmap for CCA in Q2CY09
It is not clear how you would get 8 lines come into one – if this is Analog DID then only 1 call inbound is supported, no outbound calls are supported on Analog DID. UC500 can support 8 analog lines, but each line needs to have its own RJ11 connection.
Per link below, call recording is currently supported with software pack 4.2.7
Early adopter software pack in July 08 will enhance solution by adding a softkey to allow call recording to be initiated with a single softkey press.
Voice traffic is 100% real time.
For details on how to edit or add content, please refer to the Supportwiki Instructions
Links that will require partner-level access will have a lock icon next to it. Further details for becoming a Cisco Registered Partner is available here
