Running 1.01 code on SRP520W-U products.
520
By default, SRP520W-U products are shipped with 1.02.xx firmware, which is the tested and supported release train for this series of products.
If you need to run 1.01 release firmware, this is possible, however you MUST factory reset before AND after changing release train.  This reset process is required whether changing from 1.01.xx to 1.02.xx code, or vice versa.
