linksysinfo
Level 4
Level 4
At time of writing I don't know if this includes the RV042G that is due to be released in the next few days. perhaps someone from Cisco can comment on this?
Te-Kai Liu
Level 7
Level 7
The release note can be found at the bottom of the page.
http://www.cisco.com/en/US/products/ps9923/prod_release_notes_list.html
linksysinfo
Level 4
Level 4
Tekai
cant seem to find the 4.2.1.02 release notes on that page though.
Te-Kai Liu
Level 7
Level 7
linksysinfo
Level 4
Level 4
Updated.... This is the initial release of firmware for the RV042G router.
mistlandou
I have the RV016, I can't tell if it's V3 hardware.  Where can I find out and what would happen if a older router had the new firmware specified for V3 flashed onto it?
linksysinfo
Level 4
Level 4
What firmware revision do you have on the RV016?
if you flash v3 on anything else than a v3 router you would either fail or it will brick your router.
