Its best if the RV110W hold/has your router public ip address so if you're using DSL then your modem needs to be bridged and PPPOE information enter in the RV110W under pppoe. now if you have cable and it's just a cable modem then the RV110W should pull the public ip address. If it don't i would call the cable company/DSL company and have them assist you with getting your public ip address. If they say we don't support 3rd party routers then have them walk you through getting the public ip address on your computer and then you can just mirror that configuration onto the router afterwards. After this if you need assistance please give SBSC @ call @ support numbers and open a support case with next available engineers
I am pretty certain that this has worked in the past but I'm am needing to go to fiber (instead of copper) for a long run at an entertainment venue. Ports 27 and 28 on the SG300-28 switches are trunked as is port 10 on the SG300-10, 2x VLANs on all s...
view more
Hi all. I gona to change my old Cisco ASA 5510 to Cisco 1010. Could you share your thoughts if it's equal changing? My main problem is low IPsec VPN throughput. Does this change help me to provide higher IPsec VPN throughput? C...
view more
and how can I deactivate it. My switches are connecting to the following IPs and fail because we are using SSL interception so I can see this failed connections...What is it for and where is it switched off? IPs:18.205.167.734.192.246.1018.205.1...
view more
Hello Everyone.I am facing a strange issue with my Cisco SG300-20 switch. It was connected with our Local area network and everything was working fine since last 2 months. But suddenly today all the devices connected to this switch were disconnected. I ch...
view more
