Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
Single Number Reach (SNR) Basic Configuration Guide
2925
This is a very basic guide with implementing Single Number Reach (SNR) on a UC-500/520 system, it will require tweaking according to your needs. If you get stuck on anything please refer to the following link below: http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmesnr.html. Cheers, David. #############Ephone-Template Configuration#################### ephone-template 1 softkeys idle Redial Gpickup Cfwdall Dnd Mobility softkeys connected Hold Endcall LiveRcd Trnsfer Mobility Confrn TrnsfVM Park type 7975 ##The above context needs to be added or modified, you may be required to adjust this according to the customer requirements## ##Also make note of the "Type" this will also be required to create different templates for each phone type, there ## ##is no generic Template that can be used, you can not add more then one type this does not work## ############Ephone-DN configurstion########################## ephone-dn 1 dual-line number secondary no-reg primary pickup-group 1 label description name mobility call-forward busy call-forward noan timeout 10 snr delay 4 timeout 10 ##You may need to adjust the timeouts according to testing and what the customer would like to have, keep in mind that long## ##Timeouts on the SNR could be a problem, I.E delayed ringing after the call has been answered on the Mobile device## ##Anything that has "<>" attached to it, needs to be modified accordingly to the system parameters## ############Ephone Configuration############################# ephone 1 button 1:1 ephone-template 1 ##In this section the most important thing is the Ephone-Template assignment, make sure you assign the correct template## ##That corresponds to the phone type, if not certain functions may not work due to code structure## ##Configure the rest of the ephone according to system design and planning##
