Maulik Shah
Level 5
Level 5
version 1.1
ttrentler
Level 4
Level 4
Yes, but it is not supported from the CCA GUI.  You would have to configure this from the commandline
Steven Smith
Level 7
Level 7
You need the 8.0.0 software pack for this and it is only supported in command line right now.
Eivind Jonassen
Level 4
Level 4
Could you please provide me with the config and maybe some documentation link?
Eivind
Dimitris Mingos
Hi Ted,
Can you pls explain how skype solved your DTMF.
Thank you
Dimitris
ttrentler
Level 4
Level 4
Dimitris, Skype had a mis-configuration on some of their SIP Gateways.  They changed the config on all of the affected Gateways.
dnoordzy1066
Community Member
Would anyone be able to provide the CLI configuration.  I have cisco cme and would like to configure it for Skype for SIP.
eduardo.righi
Community Member
Would anyone be able to provide the CLI configuration. I have cisco 2821
brad.coats
Community Member
Hi, all!
I'm working on setting up the same on a 3725 with multiple existing trunks to multiple existing providers.  Anybody have any luck setting Skype for SIP trunks up on an IOS device and have a config they're willing to share?
Thanks!
