on 09-28-2009 05:26 PM
Yes, but it is not supported from the CCA GUI. You would have to configure this from the commandline
You need the 8.0.0 software pack for this and it is only supported in command line right now.
Could you please provide me with the config and maybe some documentation link?
Eivind
Hi Ted,
Can you pls explain how skype solved your DTMF.
Thank you
Dimitris
Dimitris, Skype had a mis-configuration on some of their SIP Gateways. They changed the config on all of the affected Gateways.
Would anyone be able to provide the CLI configuration. I have cisco cme and would like to configure it for Skype for SIP.
Would anyone be able to provide the CLI configuration. I have cisco 2821
Hi, all!
I'm working on setting up the same on a 3725 with multiple existing trunks to multiple existing providers. Anybody have any luck setting Skype for SIP trunks up on an IOS device and have a config they're willing to share?
Thanks!
