| SD205 5-Port 10/100 Switch End-of-Life May 12, 2010 Five autosensing 10/100 switched ports with auto MDI/MDI-X crossover detection that can significantly increase a small businesses network speed. |
| SD208 8-Port 10/100 Switch Eight autosensing 10/100 switched ports with auto MDI/MDI-X crossover detection that can significantly increase a small businesses network speed. |
| SD208P 8-Port 10/100 Switch with PoE Eight 10/100 auto sensing ports with Power over Ethernet on four ports to power network attached devices. Includes auto MDI/MDI-X crossover detection and a compact size to provide multiple placement options. |
| SD216 16-Port 10/100 Switch Sixteen autosensing 10/100 switched ports with auto MDI/MDI-X crossover detection that can significantly increase a small businesses network speed. Compact size fits into any environment -- includes wall-mount slots. |
| SD2005 5-Port 10/100/1000 Gigabit Switch A 5-Port 10/100/1000 Gigabit switch with non-blocking, full wire speed switching for a 10, 100, and 1000 Megabit network. Drop this switch in place of a current workgroup hub or switch, and businesses can upgrade high-requirement workstations to full Gigabit speeds as necessary, while continuing to service other clients at their current speeds. |
| SD2008 8-Port 10/100/1000 Gigabit Switch An 8-Port 10/100/1000 Gigabit switch with non-blocking, full wire speed switching for a 10, 100, and 1000 Megabit network. Drop this switch in place of a current workgroup hub or switch, and businesses can upgrade high-requirement workstations to full Gigabit speeds as necessary, while continuing to service other clients at their current speeds. |
| SR216 16-Port 10/100 Switch Sixteen autosensing 10/100 switched ports with auto MDI/MDI-X crossover detection that can significantly increase a small businesses network speed. Suitable for rack mounting. |
| SR224 24-Port 10/100 Switch Twenty-four autosensing full duplex 10/100 switched ports with auto MDI/MDI-X crossover detection that can significantly increase a small businesses network speed. Suitable for rack mounting. |
| SR224G 24-Port 10/100 + 2-Port Gigabit Switch + 2 MiniGBIC Twenty-four autosensing full duplex 10/100 switched ports with auto MDI/MDI-X crossover detection that can significantly increase a small businesses network speed. Includes two Gigabit (10/100/1000BaseTX) MDI/MDI-X ports, and two mini GBIC expansion ports. Suitable for rack mounting. |
| SR224R 24-port 10/100 Switch - 19-inch chassis Twenty-four autosensing full duplex 10/100 switched ports. Can run at high speeds of up to 200 Mbps in full-duplex mode, an ideal transfer rate for a growing network. Advanced network practices to help ensure data quality. Suitable for rack mounting. |
| SR2016 16-Port 10/100/1000 Gigabit Switch A 16-Port 10/100/1000 Gigabit switch with non-blocking, full wire speed switching for a 10, 100, and 1000 Megabit network. Drop this switch in place of a current workgroup hub or switch, and businesses can upgrade high-requirement workstations to full Gigabit speeds as necessary, while continuing to service other clients at their current speeds. Suitable for rack mounting. |
| SR2024 24-Port 10/100/1000 Gigabit Switch Twenty-four 10/100/1000 Mbps, half/full duplex, switched ports, and two Mini-GBIC expansion ports. Forwards and filters packets at non-blocking, full wire speed. All ports have auto speed negotiation and auto MDI/MDI-X crossover detection. |
| SR2024C 24-Port 10/100/1000 Gigabit Switch A 24-port Gigabit switch with 2 Mini-GBIC expansion ports in a compact form factor. Forwards and filters packets at non-blocking, full wire speed. All ports have auto speed negotiation and auto MDI/MDI-X crossover detection. |
