Please be advised, the GuideMe Wizard is no longer available on the Small Business Support Community. For search capability please use the community search field to find content related to Cisco Small Business documents, videos, and discussions.
SPA ATA and Gateway Documentation
47637
Don't know what you need or where to look?
Use this Document Map to locate everything SPA112, SPA122, SPA232D, SPA8000, SPA8800, PAP2, PAP2T, SPA2102, & SPA3102 related.
Datasheets
ProductPDF
SPA112Download
SPA122Download
SPA232DDownload
PAP2TDownload
SPA2102Download
SPA3102Download
SPA8000Download
SPA8800Download
WRP400Download
Configuration Guides
Quick Start Guides [SPA112, SPA122, SPA232D, PAP2T, SPA2102, SPA3102, SPA8000, SPA8800, WRP400] (no longer avaiable)
Cisco Small Business Analog Terminal Adapter Administration Guide [SPA112, SPA122, SPA232D, PAP2T, SPAx102, SPA8x00, WRP400]
Cisco Small Business Analog Terminal Adapter Provisioning Guide [SPA1x2 and SPA232D]
Cisco IP Telephony Devices Provisioning Guide [PAP2T, SPAx102, SPA8x00, WRP400, SPA3xx and SPA5xx]
WRP400 User Guide
App Notes
SPA ATAs Skype For SIP interoperability app note
Configuring the Cisco SPA8800 IP Telephony Gateway in an Asterisk Environment
Security in IP Telephony - Activating SIP over TLS on SPA Voice Products
Integrating the UC500 with the SPA8000 FXS Gateway
Other configuration documents
SPA122 Web-UI Administration Access using the WAN Port
Generating a sample configuration file for SPA Voice products
Field Notice: spacroot.crt Deprecated
Instructions for creating signed SSL Certificates for SPA Voice products
IVR [Integrated Voice Response] Codes
Routing calls between PSTN and VoIP with a SPA3102
SPA8000: Configuration Management
SPA ATA: Fax--T.38 Basic Configuration
SPA ATA: Voice-Fax-Voice--Basic Configuration
SPA232D & SPA302D: From Getting Started to Advanced Call Routing Scenarios
Troubleshooting documents
SPA1xx Resync_At and other parameters taking on strange value
Installation debugging - Blink pattern from Power LED
Debug and syslog Messages from SPA1x2 and SPA232D ATA (Analog Telephone Adapters)
SPA troubleshooting - Saving debug/syslog traces on older SPA ATAs
SPA troubleshooting - Using the slogsrv utility
SPA troubleshooting - saving a PAP2T's Configuration
SPA troubleshooting - saving a SPA2102 / SPA3102 Configuration
SPA troubleshooting - saving a SPA8000's Configuration
SPA troubleshooting - saving a WRP400's Voice Configuration
SPA-Voice Debug - Reboot Reason List
Denial of Service (DoS) Attack Prevention
SPA1xx Firmware Upgrade: No Browse Button
ATA Firmware Upgrade: Browse Button disabled [grayed-out / inactive]
Installing and Using Wireshark for Capturing Network Traffic
New SPA112 / SPA122 Not Requesting Configuration File or Firmware--Solution
Call states of SPA IP Phones and ATA devices (NewCallState syslog message)
Related Products Configuration Guides
SPA9000 Voice System Configuration Guides
SPA Phones Configuration Guides
Miscellaneous
SPA112 & SPA122 Time Zone Parameters and XML
SPA ATA Firmware & Tools
Release Notes for Firmware Revisions
WRP400: USB Modem Compatibility List and Instructions
Product Warranty
SPA ATA: Saving the XML Configuration for Analysis using the admin/config.xml URL
Retrieving SPA112 and SPA122 Configuration URL and including admin credentials in URL
Determining the firmware version on SPA112, SPA122, and SPA232D
SPA ATA Firmware Upgrade Process Explained
Webcast-ISE Deployment and Best Practices
