A couple customers have mentioned trouble with the SPA2102 dissipating heat. In order to avoid overheating, please make sure you don’t have anything stacked on top of the device and that it is placed in a well ventilated area.
We recently changed ISP's and the large increase in speed warranted an upgrade from our existing RV042 to an RV160. I started by using the settings from the RV042 as the basis for the settings in the RV160 and when I connect it to the old ISP modem, every...
view more
I have a connection between a Cisco c500 and a Cisco 3560 in trunk on a vlan (vlan id 216). When one of the 2 switches is accidentally restarted following an electrical outage, the "switchport mode access" command is added to the trunk port, removing the ...
view more
We have an SF-302-08P switch.Can I export its configuration, then import this exported configuration into a Cisco CBS-35O-8P-2G-NA switch??How should the SF-302 config be exported?? -- exclude, encrypted, plaintext??And how should it be imported?? -- runn...
view more
Hello,After 5 years of perfect usage providing extended wifi coverage to my office, my WAP321 has stopped working after a power cut. Ive tried the usual reset & turning it off and on along with downloading the Cisco FindIT application to try and ...
view more
Hello, I'm looking to create a DHCP server for 2 vLANs for a small business network. I've done this several times before on older Cisco switches, but this is my first time on the Business 350 switches. Despite what I believe is a pro...
view more
