SPA525G Phone Load Version 7-1-9 Replacement for Corrupted Version
1997
you are running SPA525G Wireless desktop phones in your UC520 environment, you may want to confirm what load thay are actually running (manually via the phone GUI, or on CLI 'show ephone phone-load').
I had noticed that my 525G was running 7-1-7 and when the phone was rebooted, it would attempt to upgrade to 7-1-9, but it would fail and stay on 7-1-7 so I investigated.
We have determined that the UC520 7.0.3 bundle zip version contains a corrupted SPA525G phone load version 7.1.9.  It is not clear if that bundle always had the corrupted phone load, so the easiest thing to do to check if you are impacted is check your file size and check your SPA525 running version
If your phone load is this size, it is probably corrupted and not running on your phone:
Directory of flash:/phones/525/
   89  -rw-     9871691  Jul 13 2009  10:22:40 -04:00  spa525g-7-1-9.bin
Replace your 7-1-9 phone load with the proper working phone load (I attached it as well as the release notes), so you can decide if you want it.
Since the name of the image is the same, you dont have to perform any CLI configuration, just replace the file as shown here.
Triad#copy tftp flash:
Address or name of remote host [192.168.20.13]?
Source filename [spa525g-7-1-9.bin]?
Destination filename [/phones/525/spa525g-7-1-9.bin]?
Accessing tftp://192.168.20.13/spa525g-7-1-9.bin...
Loading spa525g-7-1-9.bin from 192.168.20.13 (via Vlan1): !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
[OK - 9803264 bytes]
After the file is replaced, reboot the SPA525G and with tftp event debugging (as I am showing) you can confirm it works.
#debug tftp events
TFTP Event debugging is on
#term mon
000489: Aug 19 12:19:33.303: TFTP: Looking for SEP002497F055B8.cnf.xml
000490: Aug 19 12:19:33.303: TFTP: Opened system:/its/XMLDefault525G.cnf.xml, fd 10, size 1083 for process 169
000491: Aug 19 12:19:33.335: TFTP: Finished system:/its/XMLDefault525G.cnf.xml, time 00:00:00 for process 169
000492: Aug 19 12:19:33.843: TFTP: Looking for spa525g-7-1-9.BIN
000493: Aug 19 12:19:33.967: TFTP: Opened flash:/phones/525/spa525g-7-1-9.bin, fd 10, size 9803264 for process 169
000494: Aug 19 12:19:55.280: %IPPHONE-6-UNREGISTER_ABNORMAL: ephone-5:SEP002497F055B8 IP:10.1.1.15 Socket:1 DeviceType:Phone has unregistered abnormally.
Be Patient while the phone reboots and loads.
000495: Aug 19 12:21:20.159: TFTP: Finished flash:/phones/525/spa525g-7-1-9.bin, time 00:0
000496: Aug 19 12:21:29.619: TFTP: Looking for RingList.xml
000497: Aug 19 12:21:29.667: TFTP: Opened flash:/ringtones/RingList.xml, fd 10, size 2823 for process 169
000498: Aug 19 12:21:29.719: TFTP: Looking for /SPA525G-cfg.xml
000499: Aug 19 12:21:29.759: TFTP: Finished flash:/ringtones/RingList.xml, time 00:00:00 for process 169
000500: Aug 19 12:21:29.763: TFTP: Looking for DistinctiveRingList.xml
000501: Aug 19 12:21:29.807: TFTP: Opened flash:/ringtones/DistinctiveRingList.xml, fd 10, size 2823 for process 227
000502: Aug 19 12:21:29.887: TFTP: Finished flash:/ringtones/DistinctiveRingList.xml, time 00:00:00 for process 227
000503: Aug 19 12:21:29.907: TFTP: Looking for United_States/525G-tones.xml
000504: Aug 19 12:21:29.915: TFTP: Looking for United_States/525G-tones.xml
000505: Aug 19 12:21:29.927: TFTP: Looking for United_States/525G-tones.xml
000506: Aug 19 12:21:29.935: TFTP: Looking for United_States/525G-tones.xml
000507: Aug 19 12:21:29.947: TFTP: Looking for United_States/525G-tones.xml
000508: Aug 19 12:21:29.959: TFTP: Looking for United_States/525G-tones.xml
000509: Aug 19 12:21:29.967: TFTP: Looking for United_States/525G-tones.xml
000510: Aug 19 12:21:29.975: TFTP: Looking for United_States/525G-tones.xml
000511: Aug 19 12:21:29.987: TFTP: Looking for United_States/525G-tones.xml
000512: Aug 19 12:21:29.999: TFTP: Looking for United_States/525G-tones.xml
000513: Aug 19 12:21:30.007: TFTP: Looking for English_United_States/525G-kate.xml
000514: Aug 19 12:21:30.019: TFTP: Looking for English_United_States/525G-kate.xml
000515: Aug 19 12:21:30.027: TFTP: Looking for English_United_States/525G-kate.xml
000516: Aug 19 12:21:30.095: TFTP: Looking for English_United_States/525G-dictionary.xml
000517: Aug 19 12:21:30.107: TFTP: Looking for English_United_States/525G-dictionary.xml
000518: Aug 19 12:21:30.195: %IPPHONE-6-REG_ALARM: Name=SEP002497F055B8  Load=7.1.7 Last=Hard+Unknown
000519: Aug 19 12:21:30.195: TFTP: Looking for English_United_States/SCCP-dictionary.xml
000520: Aug 19 12:21:30.195: TFTP: Opened system:/its/united_states/SCCP-dictionary.xml, fd 10, size 2740 for process 169
000521: Aug 19 12:21:30.279: TFTP: Finished system:/its/united_states/SCCP-dictionary.xml, time 00:00:00 for process 169
000522: Aug 19 12:21:30.283: TFTP: Looking for English_United_States/SCCP-dictionary.xml
000523: Aug 19 12:21:30.283: TFTP: Opened system:/its/united_states/SCCP-dictionary.xml, fd 10, size 2740 for process 227
000524: Aug 19 12:21:30.343: %IPPHONE-6-REGISTER: ephone-5:SEP002497F055B8 IP:10.1.1.15 Socket:1 DeviceType:Phone has registered.
000525: Aug 19 12:21:30.367: TFTP: Finished system:/its/united_states/SCCP-dictionary.xml, time 00:00:00 for process 227
The phone will reboot on the new FW again...
000526: Aug 19 12:22:16.289: TFTP: Looking for SEP002497F055B8.cnf.xml
000527: Aug 19 12:22:16.289: TFTP: Opened system:/its/XMLDefault525G.cnf.xml, fd 10, size 1083 for process 169
000528: Aug 19 12:22:16.317: TFTP: Finished system:/its/XMLDefault525G.cnf.xml, time 00:00:00 for process 169
000529: Aug 19 12:22:16.821: TFTP: Looking for spa525g-7-1-9.BIN
000530: Aug 19 12:22:16.941: TFTP: Opened flash:/phones/525/spa525g-7-1-9.bin, fd 10, size 9803264 for process 169
000531: Aug 19 12:22:24.177: TFTP: Looking for RingList.xml
000532: Aug 19 12:22:24.221: TFTP: Opened flash:/ringtones/RingList.xml, fd 11, size 2823 for process 227
000533: Aug 19 12:22:24.241: TFTP: Finished flash:/ringtones/RingList.xml, time 00:00:00 for process 227
000534: Aug 19 12:22:24.245: TFTP: Looking for DistinctiveRingList.xml
000535: Aug 19 12:22:24.289: TFTP: Opened flash:/ringtones/DistinctiveRingList.xml, fd 11, size 2823 for process 228
000536: Aug 19 12:22:24.325: TFTP: Finished flash:/ringtones/DistinctiveRingList.xml, time 00:00:00 for process 228
000537: Aug 19 12:22:24.341: TFTP: Looking for United_States/525G-tones.xml
000538: Aug 19 12:22:24.345: TFTP: Looking for United_States/525G-tones.xml
000539: Aug 19 12:22:24.349: TFTP: Looking for United_States/525G-tones.xml
000540: Aug 19 12:22:24.353: TFTP: Looking for United_States/525G-tones.xml
000541: Aug 19 12:22:24.357: TFTP: Looking for United_States/525G-tones.xml
000542: Aug 19 12:22:24.361: TFTP: Looking for United_States/525G-tones.xml
000543: Aug 19 12:22:24.365: TFTP: Looking for United_States/525G-tones.xml
000544: Aug 19 12:22:24.369: TFTP: Looking for United_States/525G-tones.xml
000545: Aug 19 12:22:24.373: TFTP: Looking for United_States/525G-tones.xml
000546: Aug 19 12:22:24.377: TFTP: Looking for United_States/525G-tones.xml
000547: Aug 19 12:22:24.385: TFTP: Looking for English_United_States/525G-kate.xml
000548: Aug 19 12:22:24.405: TFTP: Looking for English_United_States/525G-kate.xml
000549: Aug 19 12:22:24.409: TFTP: Looking for English_United_States/525G-kate.xml
000550: Aug 19 12:22:24.461: TFTP: Looking for English_United_States/525G-dictionary.xml
000551: Aug 19 12:22:24.473: TFTP: Looking for English_United_States/525G-dictionary.xml
000552: Aug 19 12:22:24.493: %IPPHONE-6-REG_ALARM: Name=SEP002497F055B8  Load=7.1.9 Last=Hard+Unknown
000553: Aug 19 12:22:24.493: TFTP: Looking for English_United_States/SCCP-dictionary.xml
000554: Aug 19 12:22:24.493: TFTP: Opened system:/its/united_states/SCCP-dictionary.xml, fd 11, size 2740 for process 227
000555: Aug 19 12:22:24.577: TFTP: Finished system:/its/united_states/SCCP-dictionary.xml, time 00:00:00 for process 227
000556: Aug 19 12:22:24.577: TFTP: Looking for English_United_States/SCCP-dictionary.xml
000557: Aug 19 12:22:24.577: TFTP: Opened system:/its/united_states/SCCP-dictionary.xml, fd 11, size 2740 for process 228
000558: Aug 19 12:22:24.657: TFTP: Finished system:/its/united_states/SCCP-dictionary.xml, time 00:00:00 for process 228
000559: Aug 19 12:22:24.701: %IPPHONE-6-UNREGISTER_ABNORMAL: ephone-5:SEP002497F055B8 IP:10.1.1.15 Socket:1 DeviceType:Phone has unregistered abnormally.
000560: Aug 19 12:22:24.701: %IPPHONE-6-REGISTER: ephone-5:SEP002497F055B8 IP:10.1.1.15 Socket:11 DeviceType:Phone has registered.
000561: Aug 19 12:22:32.961: TFTP: Looking for /SPA525G-cfg.xml
000562: Aug 19 12:22:42.030: TFTP: Finished flash:/phones/525/spa525g-7-1-9.bin, time 00:00:25 for process 169
Confirm load
#show ephone phone-load
DeviceName        CurrentPhoneload       PreviousPhoneload      LastReset
SEP001F6C7FF977    SCCP45.8-4-2S                                Initialized
SEP001201AD3893    SCCP70.8-4-2S          SCCP70.8-4-2S         TCP-timeout
SEP001201AD38E3    SCCP70.8-4-2S                                Initialized
SEP002255D48763   CP7921G-1.3.3          CP7921G-1.2.1          Initialized
SEP001E7ABBAECA   CP7921G-1.3.3          CP7921G-1.2.1          Initialized
SEP002497F055B8   7.1.9                  7.1.7                  Hard+Unknown
Confirm phone is stable:
sh ephone 525G
ephone-5[4] Mac:0024.97F0.55B8 TCP socket:[11] activeLine:0 REGISTERED in SCCP ver 8/8 SPCP ver 1/1
mediaActive:0 offhook:0 ringing:0 reset:0 reset_sent:0 paging 0 debug:0 caps:12
IP:10.1.1.15 3212 CP-525G  keepalive 5 max_line 5
button 1: dn 10 number 201 CH1   IDLE         CH2   IDLE
Preferred Codec: g711ulaw
Username: spa525g Password: test123
