Hi allMy first time posting on here so I'm hope you all have patience with me thanks in advance.What I have done through the web GUI is set up two vlans, vlan2 and vlan3 with different ip's with dchp pool. They work fine, and there is no communication bet...
view more
Hi I just got this switch and really like it, but now I see this "In pause frame" on port 1 where my Ruckus Accesspoint is plugged in.I tried to refresh and it occur every minut or so, see attaced pictures. If I check out the "Trafic error informatio...
view more
Hi. We just bought Cisco C921-4P router. We tried to enable Web GUI but nothing works. When i go to routers ip address there is simple text-based homepage.http and https servers are enabled
Hello, I have a couple of old SG350XG switches, and I am trying to generate a CSR and create a new custom SSL certificate.After applying the generated certs, Chrom/Edge etc still does not trust the cert because there is no SAN. The CSR gives me no op...
view more
