Alberto Montilla
This  is the SRP500 configuration for Telmex (Mexico) ADSL Services, big  thanks to Rogelio Valtierra.
Dynamic IP Address assignment
Below  is the configuration for Telmex ADSL  Service using dynamic IP  Address:
  • Internet Connection Type: PPPoE - PPP over Ethernet
  • ATM  PVC: Static
  • VPI: 8, VCI: 81 (as  indicated by Telmex)
  • Username:  <as indicated by Telmex>
  • Password: <as indicated by Telmex>
  • Connection: Keepalive
  • MTU: Manual, 1492
Static  IP Address (TBC)
TBC
This is very Helpful. But I have a Question :
If a have a static ip address with Telmex, it's the same configuration? Tanks.
Andrew Hickman
Unless you have been told othewise by Telmex, the configuration will be the same as above.  For PPP, addressing is generally assigned dynamically - in your case, you are always assigned the same (static) address.
Andy
Hi:
Yesterday I was setting up an SRP527W with Telmex, but not work. The 2 LEDs are green (CD-DATA), username and password correctly, but Telmex did not assign a Public IP to the router. Any ideas?
Regards.
Julio
rvaltier
Julio,
Please login as admin go to quick setup -> WAN Setup and be sure that:
Encapsulation = PPPoE,
Multiplexing = LLC
VPI/VCI Autodetect o Disable
and most important:
VPI=8
VCI=81
Rogelio V.
This is my current settings and it worked yesterday (Dynamic IP Address assignment over Telmex) :
Quick Setup - - > Basic Configuration Setup - - > Wan Setup
Encapsulation : PPPoE
Multiplexing: VC
QoS type: UBR
VPI/VCI Auto Detect
Virtual Circuit
    VPI 8
    VCI 81
PPPoE Settings
    Interface Setup - - > WAN - - > Internet Setup
    DSL Modulation: ADSL2+
    MTU: Manual Size 1492
    On Wednesday I was in another city (Mexico,DF) but this settings did not work (No Internet Connection) . Then yesterday I returned to my city(Mexico,SLP), but in my office the same configuration worked properly ( Internet Connection ). WTF ? Any idea?
    Tanks Rogelio, today proves changing the multiplexing to LLC . (Whats the difference?)
    Regards.
    Julio Mtz
    rvaltier
    Julio,
    It is the type of encapsulation, both are pretty much the same, VC-MUX is a form of network traffic control. It is used in situations where multiplexing is preferable to switching.
    If you take a look on your old the modem, it is configured to work with LLC.
    You may try to test latest SRP520 Maintenance Release 3 (MR3)
    https://supportforums.cisco.com/docs/DOC-11342
    regards
    Rogelio V.
