Dear all,Maybe you face the same issue as me, here is the problem: I set some ntp servers on my switch with poll interval enable. After registering the different servers, it get the time correctly and show them as "up" and the next day, they are all "down...
view more
I have the Cisco sg200-26 smart switch. I have this connected : Modem (port 2 on modem) to Cisco Switch from switch to computer, switch also has multiple other ethernet devices connected. I also have a Linsys Velop router als...
view more
Hi, how can I set login password on Cisco SPA504 IP phone? When I login, I can change user password and it works (I can't login to phone without password), but problem is that this block keys on the phone also...? Which is default admin password?
S/N : FOC1335Z0LK Above mentioned serial number switch we using please provide the warrenty periods, its in warrenty or not . thanks ,Ajithkannan.A,8825605184.
Buenos dias los problemas que tengo son 21) el programa por mas que este maracado en el iniciode windows, el mismo no carga automaticamente ni inicia solo al ingresar a windws2) cada tanto y de manera aleatoria el programa se desinstala solo, es deci...
view more
