Please be advised, the GuideMe Wizard is no longer available on the Small Business Support Community. For search capability please use the community search field to find content related to Cisco Small Business documents, videos, and discussions.
UC320 SIP trunk configuration for sipcall.ch (Switzerland)
2156
Tested by: Calistus Che, sipcall.ch
UC320W FW release: 2.1.1(7) with Region Pack for Switzerland
  • Provider: Generic SIP Provider
  • Description: sipcall
  • Proxy: business1.voipgateway.org
  • Registration:  Checked (Client-server SIP  trunk, registration required)
  • Outbound Proxy: business1.voipgateway.org
  • Call  Capacity: 12
  • Prefix # w/"+41" : Uncheck (uses UK national numbering plan)
  • Company  Name: <Your company name> (this will appear as the Display Name field on SIP messaging)
  • Account  ID:  <Account Phone number as provided by  the ITSP>
  • SIP domain name: business1.voipgateway.org
  • Authentication  ID: <Same as Account ID>
  • Password:  <As provided by the ITSP>
  • SRV  Recorded Lookup: Uncheck
  • SRV Auto Prefix: Uncheck
  • NAT Mapping: Uncheck
  • Send NAT Keepalive: Uncheck
Systemwide parameters
  • Codec: G711a/G729
  • Outbound FAX:  T.38/Passthrough
Known issues with tested release:
  • Issues with incoming calls forwarded to external numbers, no audio
  • Issues with fax reception, both T.38 and pass through
  • Issues with incoming call transfer from IP phone to analog phone
