Please be advised, the GuideMe Wizard is no longer available on the Small Business Support Community. For search capability please use the community search field to find content related to Cisco Small Business documents, videos, and discussions.
UC320 SIP trunk configuration for VoIP Unlimited (UK)
2232
Tested by: Steve Bieniek, VoIP Unlimited
UC320W FW release: 2.1.0(22)
  • Provider: Generic SIP Provider
  • Description: VoIP Unlimited
  • Proxy: sip.voip-unlimited.net
  • Registration: Checked (Client-server SIP trunk, registration required)
  • Outbound Proxy: sip.voip-unlimited.net
  • Call Capacity: 12
  • Prefix # w/"+44" : Uncheck (uses UK national numbering plan)
  • Company Name: <Your company name> (this will appear as the Display Name field on SIP messaging)
  • Account ID:  <Account Phone number as provided by the ITSP>
  • SIP domain name: sip.voip-unlimited.net
  • Authentication ID: <Same as Account ID>
  • Password: <As provided by the ITSP>
  • SRV Recorded Lookup: Checked
  • SRV Auto Prefix: Checked
  • NAT Mapping: Checked
  • Send NAT Keepalive: Checked
         Systemwide parameters
  • Codec: G711a
  • Outbound FAX:  T.38
  • NAT STUN Server: stun.voip-unlimited.net:10000 (Supports also static IP address mapping if using static public IP)
Known Issues:
Community Member
Some additional supporting notes from our side:
* The UC320 can process a maximum of 12 external calls whereas VoIP Unlimited provides "Unlimited" channels for a flat fee of £10.99 plus vat per month
* G711u and G729 codecs are also supported
Steve Bieniek
sales@voip-unlimited.net
Tel: 01202 612000
