Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
UC500 SIP Trunk to BabyTel
1774
SIP Trunk info
Name of SP BabyTel
Dial Plan Locale (Country) NorthAmerica
Fields to show on the SIP Trunk tab:
Proxy Server (Primary) Y
Proxy Server (Backup) N
Registrar Server Y
Outbound Proxy Server Y
Digest Authentication (username / password) Y
Other:
Fax protocol  G711ulaw upspeed
DTMF RFC 2833  with RTP payload type 101
Register all DIDs N
If register all DIDs, then - all DIDs have NA
DSCP marking Signaling cs3
DSCP marking RTP ef
SIP Destination Port 5065
Attahced is a template you can import into CCA 2.1 or higher. Info on how to upload a template is below:
https://www.myciscocommunity.com/docs/DOC-9168
This has been tested by ciscojoe837
Create
Recognize Your Peers
Polls
When looking for support content like videos or documents, how do you arrive at our support content?
Help us support you!
