The table below lists the UC500 hardware SKUs
UC520 Hardware Part Number | UC520 Part Description |
UC520-8U-4FXO-K9 | • 8 User configuration with 4 PSTN trunks (FXO), 4 Analog ports (FXS), 8 PoE ports, 1 VIC slot for expansion • Feature licenses for call control, voicemail and Cisco Unified IP Phones |
UC520W-8U-4FXO-K9 | • 8 User configuration with 4 PSTN trunks (FXO), 4 Analog ports (FXS), 8 PoE ports, 1 VIC slot for expansion, Integrated Wireless • Feature licenses for call control, voicemail and Cisco Unified IP Phones |
UC520-8U-2BRI-K9 | • 8 User configuration with 2 BRI trunks (BRI), 4 Analog ports (FXS), 8 PoE ports, 1 VIC slot for expansion • Feature licenses for call control, voicemail and Cisco Unified IP Phones |
UC520W-8U-2BRI-K9 | • 8 User configuration with 2 BRI trunks (BRI), 4 Analog ports (FXS), 8 PoE ports, 1 VIC slot for expansion, Integrated Wireless • Feature licenses for call control, voicemail and Cisco Unified IP Phones |
UC520-16U-4FXO-K9 | • 16 User configuration with 4 PSTN trunks (FXO), 4 Analog ports (FXS), 8 PoE ports, 1 VIC slot for expansion • Feature licenses for call control, voicemail and Cisco Unified IP Phones Note: requires an eight (8) port Cisco Catalyst Express 520 switch |
UC520W-16U-4FXO-K9 | • 16 User configuration with 4 PSTN trunks (FXO), 4 Analog ports (FXS), 8 PoE ports, 1 VIC slot for expansion, Integrated Wireless • Feature licenses for call control, voicemail and Cisco Unified IP Phones Note: requires an eight (8) port Cisco Catalyst Express 520 switch |
UC520-16U-2BRI-K9 | • 16 User configuration with 2 BRI trunks (BRI), 4 Analog ports (FXS), 8 PoE ports, 1 VIC slot for expansion • Feature licenses for call control, voicemail and Cisco Unified IP Phones Note: requires an eight (8) port Cisco Catalyst Express 520 switch |
UC520W-16U-2BRI-K9 | • 16 User configuration with 2 BRI trunks (BRI), 4 Analog ports (FXS), 8 PoE ports, 1 VIC slot for expansion, Integrated Wireless • Feature licenses for call control, voicemail and Cisco Unified IP Phones Note: requires an eight (8) port Cisco Catalyst Express 520 switc |
UC520-24U-8FXO-K9 | • 24 User configuration with 8 PSTN (FXO), 4 Analog ports (FXS), 8 PoE ports, 1 VIC slot for expansion • Feature licenses for user configurations of call control, voicemail and Cisco Unified IP Phones Note: requires a twenty-four (24) port Cisco Catalyst Express 520 switch |
UC520-24U-4BRI-K9 | • 24 User configuration with 4 BRI trunks (BRI), 4 Analog ports (FXS), 8 PoE ports, 1 VIC slot for expansion • Feature licenses for call control, voicemail and Cisco Unified IP Phones Note: requires a twenty-four (24) port Cisco Catalyst Express 520 switch |
UC520-32U-8FXO-K9 | • 32 User configuration with 8 PSTN trunks (FXO), 4 Analog ports (FXS), 8 PoE ports, 1 VIC slot for expansion • Feature licenses for user configurations of call control, voicemail and Cisco Unified IP Phones Note: requires a twenty-four (24) port Cisco Catalyst Express 520 switch |
UC520-32U-4BRI-K9 | • 32 User configuration with 4 BRI trunks (BRI), 4 Analog ports (FXS), 8 PoE ports, 1 VIC slot for expansion • Feature licenses for call control, voicemail and Cisco Unified IP Phones Note: requires a twenty-four (24) port Cisco Catalyst Express 520 switch |
UC520-48U-12FXO-K9 | • 48 User configuration with 12 PSTN trunks (FXO), 4 Analog ports (FXS), 8 PoE ports • Feature licenses for user configurations of call control, voicemail and Cisco Unified IP Phones Note: requires two twenty-four (24) port Cisco Catalyst Express 520 switch |
UC520-48U-6BRI-K9 | • 48 User configuration with 6 BRI trunks (BRI), 4 Analog ports (FXS), 8 PoE ports • Feature licenses for call control, voicemail and Cisco Unified IP Phones Note: requires two twenty-four (24) port Cisco Catalyst Express 520 switch |
UC520-48U-T/E/F-K9 | • 48 User configuration with a T1/E1 interface, 4 additional PSTN trunk ports (FXO), 4 Analog ports (FXS), 8 PoE ports, 1 VIC slot for expansion • Feature licenses for user configurations of call control, voicemail and Cisco Unified IP Phones Note: requires two twenty-four (24) port Cisco Catalyst Express 520 switch |
UC520-48U-T/E/B-K9 | • 48 User configuration with a T1/E1 interface, 2 additional BRI trunk ports, 4 Analog ports (FXS), 8 PoE ports, 1 VIC slot for expansion • Feature licenses for user configurations of call control, voicemail and Cisco Unified IP Phones Note: requires two twenty-four (24) port Cisco Catalyst Express 520 switch |
The table below lists the UC500 software SKUs
UC520 Software Part Number | UC520 Software Part Description |
SL-UC520-16UPG= | Software license upgrade from 8 to 16 users |
SL-UC520-32UPG= | Software license upgrade from 24 to 32 users |
SL-UC520-24-48UPG= | Software license upgrade from 24 to 48 users |
SL-UC520-48UPG= | Software license upgrade from 32 to 48 users |
SL-UC520-64UPG= | Software license upgrade from 48 to 64 users |
The table below lists other UC500 SKUs
UC520 Part Number | UC520 Part Description |
PWR-UC500-220W= | Cisco Unified 500 Desk Top Power Adapter 100-240VAC |
ACS-UC500RM-19= | 19 inch Rack Mount Kit for the Cisco Unified 500 (8/16 User) |
MEMUC500-128CF= | 128MB CF for the Cisco Unified 500 Series |
ACS-3825RM-19= | 19 inch Rack Mount Kit for the Cisco Unified 500 (24 User and above) |
The table below lists UC500 Support SKUs
UC520 Support Part Number | UC520 Support Part Description |
CON-SNT-8U2BRI | SMARTnet 8x5xNBD for 8U Unified CME Base, Cisco Unity Express, and phone FL w/2BRI, 1VIC |
CON-SNT-W8U2BRI | SMARTnet 8x5xNBD for 8U Unified CME Base, Cisco Unity Express, and phone FL w/2BRI, 1VIC Wi-Fi |
CON-SNT-8U4FXO | SMARTnet 8x5xNBD for 8U Unified CME Base, Cisco Unity Express, and phone FL w/4FXO, 1VIC |
CON-SNT-W8U4FXO | SMARTnet 8x5xNBD for 8U Unified CME Base, Cisco Unity Express, and phone FL w/4FXO, 1VIC Wi-Fi |
CON-SNT-16U2BRI | SMARTnet 8x5xNBD for 16U Unified CME Base, Cisco Unity Express, and phone FL w/2BRI, 1VIC |
CON-SNT-W16U2BRI | SMARTnet 8x5xNBD for 16U Unified CME Base, Cisco Unity Express, and phone FL w/2BRI, 1VIC Wi-Fi |
CON-SNT-16U4FXO | SMARTnet 8x5xNBD for 16U Unified CME Base, Cisco Unity Express, and phone FL w/4FXO, 1VIC |
CON-SNT-W16U4FXO | SMARTnet 8x5xNBD for 16U Unified CME Base, Cisco Unity Express, and Phone FL w/4FXO, 1VIC Wi-Fi |
CON- SNT-24U8FXO | SMARTnet 8x5xNBD for 24U Unified CME Base, Cisco Unity Express, and Phone FL w/ 8FXO, 1VIC |
CON-SNT-24U4BRI | SMARTnet 8x5xNBD for 24U Unified CME Base, Cisco Unity Express, and Phone FL w/ 4BRI, 1VIC |
CON-SNT-32U8FXO | SMARTnet 8x5xNBD for 32U Unified CME base, Cisco Unity Express, and phone FL w/8FXO, 1 VIC |
CON-SNT-32U4BRI | SMARTnet 8x5xNBD for 32U Unified CME base, Cisco Unity Express, and phone FL w/4BRI, 1VIC |
CON-SNT-48U12FXO | SMARTnet 8x5xNBD for 48U Unified CME base, Cisco Unity Express, and phone FL w/12FXO, 1VIC |
CON-SNT-48U6BRI | SMARTnet 8x5xNBD for 48U Unified CME base, Cisco Unity Express, and phone FL w/6BRI, 1VIC |
CON-SNT-48UTEF | SMARTnet 8x5xNBD for 48U Unified CME base, Cisco Unity Express, and phone FL w/T1, 1VIC |
CON-SNT-48UTEB | SMARTnet 8x5xNBD for 48U Unified CME base, Cisco Unity Express, and phone FL w/T1, 1VIC |
CON-OSP-8U2BRI | Onsite 4 hour Advanced Replacement for 8U Unified CME Base, Cisco Unity Express, and phone FL w/2BRI, 1VIC |
CON-OSP-W8U2BRI | Onsite 4 hour Advanced Replacement for 8U Unified CME Base, Cisco Unity Express, and phone FL w/2BRI, 1VIC Wi-Fi |
CON-OSP-8U4FXO | Onsite 4 hour Advanced Replacement for 8U Unified CME Base, Cisco Unity Express, and phone FL w/4FXO, 1VIC |
CON-OSP-W8U4FXO | Onsite 4 hour Advanced Replacement for 8U Unified CME Base, Cisco Unity Express, and phone FL w/4FXO, 1VIC Wi-Fi |
CON-OSP-16U2BRI | Onsite 4 hour Advanced Replacement for 16U Unified CME Base, Cisco Unity Express, and phone FL w/2BRI, 1VIC |
CON-OSP-W16U2BRI | Onsite 4 hour Advanced Replacement for 16U Unified CME Base, Cisco Unity Express, and phone FL w/2BRI, 1VIC Wi-Fi |
CON-OSP-16U4FXO | Onsite 4 hour Advanced Replacement for 16U Unified CME Base, Cisco Unity Express, and phone FL w/4FXO, 1VIC |
CON-OSP-W16U4FXO | Onsite 4 hour Advanced Replacement for 16U Unified CME Base, Cisco Unity Express, and Phone FL w/4FXO, 1VIC Wi-Fi |
CON-OSP-24U8FXO | Onsite 4 hour Advanced Replacement for 24U Unified CME Base, Cisco Unity Express, and Phone FL w/ 8FXO, 1VIC |
CON-OSP-24U4BRI | Onsite 4 hour Advanced Replacement for 24U Unified CME Base, Cisco Unity Express, and Phone FL w/ 4BRI, 1VIC |
CON-OSP-32U8FXO | Onsite 4 hour Advanced Replacement for 32U Unified CME base, Cisco Unity Express, and phone FL w/8FXO, 1 VIC |
CON-OSP-32U4BRI | Onsite 4 hour Advanced Replacement for 32U Unified CME base, Cisco Unity Express, and phone FL w/4BRI, 1VIC |
CON-OSP-48U12FXO | Onsite 4 hour Advanced Replacement for 48U Unified CME base, Cisco Unity Express, and phone FL w/12FXO, 1VIC |
CON-OSP-48U6BRI | Onsite 4 hour Advanced Replacement for 48U Unified CME base, Cisco Unity Express, and phone FL w/6BRI, 1VIC |
CON-OSP-48UTEF | Onsite 4 hour Advanced Replacement for 48U Unified CME base, Cisco Unity Express, and phone FL w/T1, 1VIC |
CON-OSP-48UTEB | Onsite 4 hour Advanced Replacement for 48U Unified CME base, Cisco Unity Express, and phone FL w/T1, 1VIC |
