Hi all. I gona to change my old Cisco ASA 5510 to Cisco 1010. Could you share your thoughts if it's equal changing? My main problem is low IPsec VPN throughput. Does this change help me to provide higher IPsec VPN throughput? C...
view more
and how can I deactivate it. My switches are connecting to the following IPs and fail because we are using SSL interception so I can see this failed connections...What is it for and where is it switched off? IPs:18.205.167.734.192.246.1018.205.1...
view more
Hello Everyone.I am facing a strange issue with my Cisco SG300-20 switch. It was connected with our Local area network and everything was working fine since last 2 months. But suddenly today all the devices connected to this switch were disconnected. I ch...
view more
Hello,We are using Cisco SG350-28 Model Network Switches, with these switches our APs (non-CISCO Make) are connected. These APs have on OS base Controller software which is installed on Windows computers. 1) Each AP has Two SSID, One is for Comp...
view more
Hello , we are trying to detect if a Cisco TAPI device ( can be IP Phone , IP Communicator etc) is disconnected from the network or powered off . From TAPI we couldnt find an option to get an event in the case of such an incident. W...
view more
