norton2011
WRVS4400N V2 ROUTER PORT PROBLEM
i set opened port 5900-5900 TCP and click enable on Single Port Forwarding page for VNC ,but it didn't work to connect VNC with internet ip 202.243.xx.xxx
i tried internal ip 192.168.3.100:5900 no any problem and can connect to VNC
i tried closed all firewall or opened winxp 5900 port and set DMZ 192.168.3.100 still not working
i using vlan 3 ,gateway 192.168.3.1
why i can't use internet ip to connect VNC ,what i missing to set ?
PLZ HELP
jasbryan
Level 6
Level 6
Just want to let you know that your configuration set up should work. I would recommend checking and making sure you are on the latest firmware 2.0.1.3. I have tested this in the lab to verify everything when port forwarding across vlans and test was successful. So after checking and making sure you are on the latest firmware if you are still having problems please give the Cisco Small Business Support a call @ 1-866-606-1866
Jason Bryant
Cisco Support Engineer
