Yes, I got it working. Still one small hurlde to overcome.
With Putty you can have an input file with your commands. For some reason I cannot get this to work yet.
Without the input file I can log-on successfully to the switch but as soon as I add the input file with the command mentioned above I get a "Server sent disconnect message"
Not sure yet what is causing this.
Remko
