Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
The following document describes how to combine fax and voice detection on the same POTS line, while presenting callers with an IVR option (prompt) to select between the two.
I can fax good in but when I call the number I hear the prompt like I should but when I press a button or just wait the 9 seconds it disconnects my call. Any idea??
