Marcos Hernandez
The following document describes how to combine fax and voice detection on the same POTS line, while presenting callers with an IVR option (prompt) to select between the two.
Bill.Lopez
I can fax good in but when I call the number I hear the prompt like I should but when I press a button or just wait the 9 seconds it disconnects my call. Any idea??
cindy toy
Level 7
Level 7
Hi Bill - I suggest that you should post your question as a discussion instead of a comment. Please post your question here: https://www.myciscocommunity.com/community/smallbizsupport/voiceandconferencing/sbcs-uc500
Cindy Toy
Cisco Small Business Support
Community Manager
