Patrick Born
If after reading the SRST Application note and the SPA Phone Administration Guide SIP Proxy Redundancy section, you find yourself needing additional help configuring redundant SIP proxies, then this application note is for you.
<end>
jlhbjnhh67
Is there a way for the phone to evaluate which proxy is closest (smaller PING rtt value) and select that proxy rather than relying on static records from DNS SRV or configuration?
stradivarius2b
Is it normal that starting to spa50x-30x-7-6-2b.bin firmware (we are now spa50x-30x-7-6-2e.bin) the proxy line
  1. MY_proxies:SRV=192.168.2.245:5060:p=1:w=50|10.10.10.10:5060:p=2:w=50 is no more working?
Julien R.
