on 08-18-2017 06:08 PM
Article ID:3857
Customization of the web portal helps to change the settings of the web portal in accordance to the requirements of the customer. These settings are applied on a per-browser basis for all the customers, so these settings will be applied on the current web browser. If there is a change in the web browser or change in the device when the portal is accessed the next time, then it is necessary to reset these options.
This article explains how to Customize Customer's Dashboard Settings on OnPlus Web Portal.
• OnPlus 100
• 7.6.2.038
Step 1. Log in to the Cisco OnPlus Portal, click the desired customer, and choose Dashboard.
Step 2. Move the mouse over Customize. A flyout menu appears which has four sets of settings to customize.
• General Settings - This helps the user to change some general settings like how the view should be and what notices need to be suppressed.
• Topology Settings - This helps the user to set how the topology of the devices should look.
• Device Listing Settings - This helps the user to edit what information needs to be listed about the device when it is clicked.
• Reset Defaults - This helps the user to reset each or all of the above settings.
Step 1. Click General Settings at the top of the flyout menu to view its settings. These settings apply both for the Network Topology view and the Device Listing view.
Step 2. Choose the default view from the Default View drop-down list. This represents how the view should be in default. The default view drop-down list has the following options:
• Auto Select — Represents the view depends on how many devices are discovered on the network. This chooses in such a way that for up to 99 devices it will use the Topology view, and for 100 or more devices it will use the Device Listing view.
• Topology — Represents all the devices on the network as topology view without any concern of how many devices are there on the network.
• Device Listing — Represents all the devices on the network as device listing view without any concern of how many devices are there on the network.
Step 3. Check the Suppress Discovery Update Notices check box to hide the discovery updates on the Dashboard. Discovery update notice is a notice for recent device discovery in the network.
Step 4. Check the Suppress Credentials Needed Notices check box to hide the credential needed notices on the Dashboard.
Step 5. Check the Suppress All Notices check box to hide the pop-up notices on the Dashboard.
Step 1. Click Topology Settings at the top of the flyout menu to view its settings. These settings apply for the Network Topology view of the Dashboard.
Step 2. Check Zoom to fit on startup to adjust the zoom percentage of the Network Topology to fit into the browser window when logged in to the portal.
Step 3. (Optional) To enable animations in the Network Topology, check Enable Animation check box.
Step 4. (Optional) To enable the display of IP addresses in the Network Topology, check Show IP Address check box.
Step 5. (Optional) To enable the display of MAC addresses in the Network Topology, check Show MAC Address check box.
Step 6. (Optional) To enable the display of the Network Interface Card (NIC) Vendor name in the Network Topology, check Show NIC Version check box.
Step 7. (Optional) To reverse the mouse action,check Reverse ALT button use on background drag check box. By default, when the user clicks and drags the ALT+LEFT mouse button in the Topology it sweeps across the Topology view, and when the user clicks and drags with the LEFT mouse button it selects multiple devices.
Step 8. Scroll the mouse and adjust the vertical spacing in the Vertical Spacing field. This adjusts the spacing between the parent and the child devices in the topology. This also makes the topology view more clearly visible for larger networks.
Step 9. Check Enlarge device on mouse over, at lower zoom level to enable the feature where a larger version of the device icon appears when mouse is moved over the icon. This makes the icons and text shown in the device icons more visible.
Step 10. Check Hover Menu Appearance Speed to indicate the duration of time it takes for the device pop-up buttons to appear moving the mouse over the device icon in the Topology View. The range is 50ms (Minimum) to 1000ms (Maximum).
Step 1. Click Device Listing Settings at the top of the flyout menu to view its settings. These settings apply for the Device Listing of the Dashboard.
Step 2. (Optional) To show the status, check State check box. The state can have any one of the three values.
• OK — This state detects that the device is present.
• MISSING — This state detects if the device was discovered earlier but is not available at present.
• ADDED — This state indicates a manually added device.
Step 3. (Optional) To indicate the general category for the device which can be Infrastructure, Telephony and so on, check Category check box.
Step 4. (Optional) To get the device class discovery when the device is discovered, check Device Class check box. It can be phone, switch, router or unknown.
Step 5. (Optional) To display the model number of the device when the device is discovered, check Device Type check box.
Step 6. (Optional) To display the information reported by the Windows Management Interface, check Windows Information (WMI) check box. The device should support WMI for this information to be reported.
Step 7. (Optional) To show the user specified device description, check Description check box.
Step 8. (Optional) To display the unique 12-digit hexadecimal identifier for the device, check MAC Address check box.
Step 9. (Optional) To display the LAN IP address of the device, check IP Address check box.
Step 10. (Optional) To indicate the IOS or firmware version of the device, check IOS/Firmware check box.
Step 11. (Optional) To number the currently enabled monitors for the device, check Monitors check box.
Step 12. (Optional) To show the device platform information which is obtained during the discovery, check Device Platform check box. For some devices this is the same as Device Type or Device Name.
Step 13. (Optional) To show the date of last backup if it is applicable, check Backup State check box. This displays Unsupported if the device does not support configuration backups through the portal.
Step 14. (Optional) To show the currently configured web connection settings for the device, check Connection Settings check box.
Step 15. (Optional) To show the discovery protocols which last gave information about the device, for example, ARP, CDP, DHCP, DDNS and so on, check Last Seen Via check box.
Step 16. (Optional) To show the device serial number if it is known, check Serial Number check box.
Step 17. (Optional) To indicate the time and date the device is first discovered on the network, check First Seen check box.
Step 18. (Optional) To show the sources which are present, check Source check box. The sources can be OnPlus Scanner, Cisco Network Assistant and ON100 Network Agent.
Step 19. (Optional) To display the label of the device, check Label check box.
Step 20. Click Select All or Select None to quickly switch between the column selection.
Step 1. Click Reset Defaults at the top of the flyout menu to view its settings. These settings apply for a category of Dashboard Customization or for all settings.
Step 2. (Optional) To reset all custom General Settings to default values, click Reset General Settings check box.
Step 3. (Optional) To reset all custom Topology Settings to default values, click Reset Topology Settings check box.
Step 4. (Optional) To reset all custom Device Listing Settings to default values, click Reset Device Listing Settings check box.
Step 5. Click Reset All to reset all custom Dashboard Settings to default values.
