I just installed and tested your application which works great. The only problem I can see is no LOGOUT option. Could you advise how to add logout when extension is logged in, please.
This document is located in section dedicated to SPA IP Phone. If you have question related to different product line ask in appropriate community - IP Telephony. There are no experts on 7911G here (sorry if I missed someone).
Please can you refer me a website to setup the extensions mobility asterisk for cisco phone 7911g or telling me if the same configuration for cisco spaXX may be using for cisco phone 7911g please thanks in advance ...
Regardless the number of accounts you will create, regardless how many times you will repeat the same question here, it is and will be wrong place for such question. If you wish for an advice then ask in appropriate place.
sorry bro for this inconvenient this is not my intention just i wanna have some answers about the extensions mobility for cisco 7911g sorry man if i mind you ...
