Alberto Montilla
Extension Mobility
This application allows the  configuration of extension mobility for users, allowing them to roam  across devices, using a username and password.
konradokon
Beginner
Beginner
I just installed and tested your application which works great. The only problem I can see is no LOGOUT option. Could you advise how to add logout when extension is logged in, please.
bernadinhans
Community Member
your tuto is very great bro i apprecied that man but  have question it is possible to setup extensions mobility  with cisco model 7911g series
Dan Lukes
Advocate
Advocate
This document is located in section dedicated to SPA IP Phone. If you have question related to different product line ask in appropriate community - IP Telephony. There are no experts on 7911G here (sorry if I missed someone).
bernadinhans
Community Member
Please can you refer me a website to setup the extensions mobility asterisk for cisco phone 7911g or telling me if the same configuration for cisco spaXX  may be using for cisco phone 7911g  please thanks in advance ...
bern.to01
Beginner
Beginner
please can someone telling me if cisco phone 7911g working with asterisk extensions mobility  i will be appreciate so much ..
Dan Lukes
Advocate
Advocate
Regardless the number of accounts you will create, regardless how many times you will repeat the same question here, it is and will be wrong place for such question. If you wish for an advice then ask in appropriate place.
bern.to01
Beginner
Beginner
sorry bro for this inconvenient this is not my intention just i wanna have some answers  about the extensions mobility for cisco 7911g  sorry man if i mind you ...
Recognize Your Peers
