cristgon
Firmware Upgrade on the WAP131. Please refer to knowledge base document # 5071.
kemitche
Has anyone had problems upgrading the WAP131 to the new WAP351_WAP131_1.0.2.2.tar file (using HTTP/HTTPS)?
I haven't been able to upgrade successfully from v1.0.1.4 - the WAP131 appears to upgrade, but after it reboots, it still has the old versions.
The previous upgrade from 1.0.0.39 to 1.0.1.4 worked fine..
