David Trad
This is a very basic Live Record CLI configuration, there are notes there to work of.
NOTE: The Live Record Softkey may not work, there are known bugs Ref: CSCsw47754
There is still some work taking place in resolving this issue, however it might something worth while working on in a Lab environment.
Any assistance required will try to assist you
Cheers,
David.
UPDATE UPDATE -
01-05-2009----
[UPDATE] UPDATE
The Live-Record Softkey is now working, however it was successful in the following environment:
CME = Operating on the latest EA-7.1.0.2 Pack
CUE = Was not upgraded during this EA upgrade version still the same prior to CME update (CME Revision 3.1)
SPA525G = Running 7-1-7 Firmware/Load
This has only been tested on the SPA525G phone at this stage, further testing is taking place on other phones. Initial issues could be due to the following:
1. Early Adopter 7.0.3 or < might have Internal coding issues
2. Phone loads might be a problem
3. DSP Issues
It all began to work once the latest updates were carried out on the system, but you will notice that the CUE was not upgraded at this stage, only the CME, so further testing on this part needs to take place as well.
The above has been reported to Cisco, however TAC and DE is yet to be advised so they can report this against the Bug Notice.
End Update----
###############CUE Configuration Guide###########################
voicemail live-record
##Again make sure that the pilot number reflects that of the same as the other parameters##
##For GUI Configuration please refer to this guide: https://www.myciscocommunity.com/docs/DOC-1415##
###############Ephone-Template Configuration Guide###############
ephone-template 1
softkeys idle Redial Gpickup Cfwdall Dnd Mobility
softkeys connected Hold Endcall LiveRcd Trnsfer Mobility Confrn TrnsfVM Park
type 7975
##The above context needs to be added/modified, you may be required to adjust this according to the customer##
##Also make note of the "Type" This will also be required to create different templates for each phone type##
##there is no generic Template that can be used, you can not add more then one type this does not work##
############Ephone Configuration Guide###########################
ephone 1
button 1:1
ephone-template 1
##In this section the most important thing is the Ephone-Template assignment, make sure you assign the correct template##
##That corresponds to the phone type, if not certain functions may not work due to code structure##
##Configure the rest of the ephone according to system design and planning##
##The Above is a CLI configuration guide, however there is a GUI guide that require minimal CLI configuration##
##However it should be noted that the Live Record softkey is not programmed with the GUI setup, there is an entirely##
##Different Sequence that takes place to initiate the live Record function##
Moderator
Level 6
Level 6
Hi David,
Thanks for taking the time to make these documents. I noticed you wrote that you were still trying to figure out how to upload images.
When you go to create a new document, choose the option "Write a New Document" instead of "Upload a File." This way, you will have an editor tool bar at the top of the description box. You will still be able to add attachments as well. In this toolbar, click on the camera icon to insert a picture. You can also create headings by changing font sizes, add lists, and much more. If you have any questions, please leave a message in .
Cisco Moderation Team
