on 04-27-2011 09:04 AM
A Platform Modifiction File (PMF) provides a mechanism to modify/override internal settings to address configuration requirements in certain environments. In some cases a PMF may be provided to address a configuration issue before it is integrated into the next firmware update. In order to maintain an easy to use Configuration Utility and minimize the number of settings that do not apply to the mainstream user, not all PMF settings will be incorporated into upcoming firmware updates. Multiple PMF files may be installed on a UC320W system.
This document maintains a list of current general availability PMF files and will be updated as new PMFs are added.
To download PMFs go to the Unified Customization Clearinghouse.
Hello Christopher,
When I try to access the http://www.ciscosbs2.com/movies/ucc/latest/ site, I get an error:
I/O Error - Error Code: 0
HTTP Error 0 reported by server"
Any clues?
Hello Christopher,
same problem for me
<< I/O Error - Error Code: 0
HTTP Error 0 reported by server" >>
Also my UC320W cannot charge "Waiting Music" and Instructions on the system (I think it will be a Cisco's Cloud Transcoding Error).
Error of charging is on file attached.
Can you help me please?
Thank you!
Hello Dramaturg7675,
Thank you for bringing this to our attention. The link now works.
Cindy
The link is not working, I need 2 pmf files, please can you fix the link. Thank you!
Same here. Link is broken. I also need to get a few PMFs
Last Date of Support: HW | The last date to receive applicable service and support for the product as entitled by active service contracts or by warranty terms and conditions. After this date, all support services for the product are unavailable, and the product becomes obsolete**. Warranty duration is based on product ship dates; refer to warranty terms and conditions for details. | January 31, 2017 |
No support mean what it says - no support. While PMF is copyrighted work, no one but Cisco can distribute it, so you are out of luck. You may try to search Internet for an unauthorized copy/distribution of particular PMF ...
