Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
Ok, but what if you want to forward incoming traffic that is within a range and not change it? For example, FTP ports 20-21? The online help for port forwarding mentions this option:
Forward to Port:To which Port the traffic should be forwarded:Same as incoming port,Specify Port
which is exactly what is required, but the feature does not exist in the interface.
Using an RV180W (1.0.3.10) - I'm following the instructions (above) and it's working for most of my computers. However, twice in as many months I find I can no longer remote (mstsc) into a computer from outside the network. I set up a bunch of custom configurations with different port numbers which forward to different computers (static IP) and 3389 for RDP. Just this morning I was connected into one of the computers, it suddenly went away and I could no longer connect. I strongly suspect it's a router issue because when I'm on the internal network I can remote into the same computer just fine. Has anyone else seen this? Is there logging I can turn on or look at to tell me exactly what's going on?
