Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
Quality of Service (QoS) is useful in networks where traffic prioritization is desired. With QoS you can separate traffic and give priority to specific types of traffic such as video or audio applications, or any other data traffic, according to your network needs. You can assign higher bandwidth to a specific portion of your network, where data traffic is higher, and reduce bandwidth to a portion of your network where data traffic is low, hence, increasing your network efficiency.
Description:HTTP 404. The resource you are looking for (or one of its dependencies) could have been removed, had its name changed, or is temporarily unavailable. Please review the following URL and make sure that it is spelled correctly.
Requested URL:/CiscoSB/Loginr.aspx
