Dimmalimm
Community Member
i configured my SA520W with 2-VLan's and one Wireless Accesspoint.
Port 1 is assinged to VLan 1
Port 2-4 are assinged to VLan2
The WLan is assinged to VLan2
The Lan-Ports works fine, every PC gets an IP-Adress vom the SA520W DHCP, but not the WLan Clients!
I can connect to the WLan Accesspoint, but not get an IP-Adress via DHCP.
If I assign a IP-Adress manuelly i can't ping any Client in every VLAN and also can't access WAN
Does anybody know what the problem is?
Sorry my Englisch is not the very best!
Steven Smith
Level 7
Level 7
Could you delete this document and make this a discussion?  I have tried this and don't see the issue.  Can you let me know what firmware version you are running?
Steven
