Alberto Montilla
[toc:faq]
SPA5xx IP Phone Firmware
Firmware can be downloaded from the Cisco Support Center (registered partners only - password required)
Please note that latest SPC utilities are located near the phone's firmware. Follow the phone's firmware link and select SPC.
SPA500 IP Phone Firmware: http://www.cisco.com/cisco/software/navigator.html?mdfid=282733326&i=rm
SPA 500 IP Phone release note location instructions: http://www.cisco.com/en/US/products/ps10499/prod_release_notes_list.html
For older SPCs (SIP Profile Compiler) click here.
Firmware for selected products can also be anonymously downloaded from here.
SPA Phone Localization (dictionaries)
Slovak dictionary provided by Lukáš: http://zssmzh.edu.sk/VoIP/prov/cisco/lang/sk.xml
[original link at: https://supportforums.cisco.com/message/3425426#3425426]
SPA30x, SPA50x, and SPA525 Localization Dictionaries for v7.4.9 Includes following 11 languages: Danish (dk), German  (de), English (en), French (fr), Italian (it), Dutch (nl), Norwegian  (no), Portuguese (pt), Russian (ru), Spanish (es), Spanish-Mexico (es_mx), Swedish  (se)
SPA30x, SPA50x, and SPA525 Dictionaries for v7.4.8 Includes following 11 languages: Danish (dk), German (de), English (en), French (fr), Italian (it), Dutch (nl), Norwegian (no), Portuguese (pt), Spanish (es), Spanish-Mexico (es_mx), Swedish (se)
SPA 50X XML Dictionaries v7.4.5-7Includes following languages: Czech (cz), Danish (dk), German (de), English (en), French (fr), Hungarian (hu), Italian (it), Dutch (nl), Norwegian (no), Polish (pl), Portuguese (pt), Russian (ru), Spanish (es), Spanish-Mexico (es_mx), Swedish (se)
These dictionaries can be used also on the CP-500 series IP phones
SPA525G XML dictionaries v7.4.5-6Includes following languages: Czech (cz), Danish (dk), German (de), English (en), French (fr), Italian (it), Dutch (nl), Norwegian (no), Portuguese (pt), Russian (ru),Spanish (es), Spanish-Mexico (es_mx), Swedish (se)
SPA525G v7.2.5
Includes following languages: German (de), English (en), French (fr), Italian (it), Dutch (nl), Norwegian (no), Portuguese (pt), Spanish (es), Swedish (se).
SPA9X2 v6.1.X Two new languages supported: Bulgarian and Norwegian.
Includes following languages: Bulgarian (bg), Czech (cz), Danish(dk), German (de), English (en), French (fr), Croatian (hr), Hungarian (hu), Italian (it), Dutch (nl), Norwegian (no), Polish (pl), Portuguese (pt), Romainan (ro), Russian (ru), Spanish (es), Swedish (se), Slovak (sk), Slovenian (sl), Turkish (tu).
Instructions for donwload, available in the SPA Phones Admin Guide (see IP Phone documentation section)
SPA9X2 v5.2.X
Paper Templates
SPA500S paper template (use this document to create and customize your own printed label for SPA500S sidecar)
SPA501G paper template (use this document to create and customize your own printed label for SPA501G IP phone)
SPA900 and SPA9000 Dial tones (partners only - password required)
XML files containing the localized dial and progress tones parameters for the SPA products, for the following countries: Denmark, France, Italy, Ireland, Netherlands, Norway, Portugal, Spain, Sweden and UK.
Other Tools
Cisco-SPA sRTP Mini Certificate Generator (Request through your local Cisco Sales representative)
Syslog/Debug Server for SPA-Voice Products (registered partners only - password required)
Ringtone utility for SPA9XX phones
SPA9000 Voice System Firmware and Tools
SPA ATAs and Gateways Firmware and Tools
SPA Phone SPC Templates for Configuration Files
SPA50xG SOS Recovery Utility and instructions
Русификация телефонов Cisco серии SPA50x, SPA30x и SPA525G2
allperfbusiness
Community Member
I'm logged as a partner and the link to the Cisco-SPA sRTP Mini Certificate Generator and the syslog link doesnt work
I received the error:
The proxy server received an invalid response from an upstream server.
The proxy server could not handle the request GET /web/partners/downloads/partner/WWChannels/sales_marketing_resources/smb/documents/mini_certificate_generator.zip.
Reason: Error reading from remote server
Could you check?
Patrick Born
Hi allperfbusiness,
Please try again, perhaps there was a server glitch when you last attempted. I have just tried the http://www.cisco.com/web/partners/downloads/partner/WWChannels/sales_marketing_resources/smb/documents/mini_certificate_generator.zip link and after logging in, was able to download the mini_certificate_generator.zip file.
Patrick
dtheodoridis
Beginner
Beginner
I'm having trouble accesing this link as well.
After logging in and clicking on it it comes up as:
The Page You Have Requested Is Not Available
Patrick Born
Hi dtheodoridis,
I have sent you a private message.
Patrick
Patrick Born
Community,
The Cisco-SPA sRTP Mini Certificate Generator is now only available through your local Cisco representative.
The links mentioned in this document have been disabled.
Apologies for the inconvenience,
Patrick
Lobster79
Community Member
craigvanham
Beginner
Beginner
Hi Guys,
The download for the latest SPA5XX Linux SPC tool is broken, it shows a size of .2MB where every other version is larger than 5 MB.
FYI: Also the eariler versions of the tools will not run on linux, I get a segment fault when I exacute it. Appears to be the same problem mentioned here https://supportforums.cisco.com/thread/2021768
Recognize Your Peers
