Alberto Montilla
Welcome to the list of SPA9000 Voice System Documentation!
SPA 9000 Frequently Asked Questions
Datasheets
ProductPDF
SPA9000 IPPBXDownload
SPA400 PSTN Gateway with VoicemailDownload
Configuration Guides
Config Guide: Installation and Configuration Guide of SPA9000 Voice System (Release 6.1, Setup Wizard 2.1)
config guide: spa9000 voice system administration guide(Release 6.1)
Config Guide: SPA9X2 and WIP310 IP Phones Administration Guide
Config Guide: SPA400 Caller ID Localization Configuration
Application Notes
New - SPA9000 Skype For SIP interoperability app note
App Note: SPA9000 Analog Phone IP PBX Configuration
App Note: Configuring WIP310 Wireless-G IP Phone with SPA9000 Voice System (Requires SPA9000 Setup Wizard 2.1)
App Note: Mediatrix 4400 ISDN Series Gateway integration with SPA9000 Voice System (Requires SPA9000 Setup Wizard 2.1)
App Note: Configuring the SPA9000 Voice System with the Cyberdata VoIP Intercomm for Door bell applications
Other related documents
New -SPA400 configuration parameter for country localization of caller ID
Configure a SPA9000 AA entry to leave Voicemail
SPA9000/SPA400 Inbound Call Routing
SPA9000 Hardware Version 1 or Version 2?
Generating a sample configuration file for SPA Voice products
Field Notice: spacroot.crt Deprecated
Instructions for creating signed SSL Certificates for SPA Voice products
SPA-Voice Products (Remote) Provisioning Guide (Registered Partners only - password required)
Cisco IP Telephony Devices Provisioning Guide
SPA400: Rebuilding a USB Drive for voicemail
Provisioning: Disabling Automatic Provisioning by the SPA9000
SPA9000 Setup Wizard: On multiple computers
SPA9000 and ATA IVR [Integrated Voice Response] Codes and Auto Attendant Message Menu [Located in ATA documentation]
SPA400 Voicemail Tree Quick Reference Card
Dial Plans: SPA9000 and SPA Phones
Troubleshooting
New - New - SPA troubleshooting - Saving a SPA9000's Configuration
New - New - SPA troubleshooting - Saving a SPA400's Configuration
New - New - SPA troubleshooting - Extracting / Pushing a Device's Configuration
New - New - SPA troubleshooting - Debug and syslog Messages from the SPA9000
New - New - SPA troubleshooting - Debug and syslog Messages from the SPA400
New - New - SPA troubleshooting - Using the slogsrv.exe Utility
SPA-Voice Debug - Reboot Reason List
SPA9000 Setup Wizard Not discovering SPA IP phones
gzielke
Beginner
Beginner
Thank you Alberto.  It's nice to have all that information in one place.
dharmesh
Beginner
Beginner
Do you have an idea that, SPA9000 would support any other standard brand SIP support?
Dharmesh
ClementCole86430
Beginner
Beginner
I have a Cisco/Linksys SPA9000/SPA400 VoIP system with SPA942 handsets at our local church. Unfortunately, our very young system admin that set it up died due to complications of diabetes.  Our network has recently been overhauled due to CV-19 requirements and need to reinstall/reconfigure the VoIP system.  We have a CD with the 2008 Documentation but can not find the Setup Wizard SW.  The links in the document to download are dead .  Sadly, he had used his own laptop to do the install when he obtained it.   Is it possible to find the SW and any of the links that Alberto suggests above so we can reinstall it and change things?  Thanks.
Recognize Your Peers
