jonatrod
Level 7
Level 7
Problem Description (User: Michael):
Trying to ssh from our QNAP to our switches and copy the running-config.
These tests are on an SG-300. When ready well be doing the same thing on all of our 2960's. So maybe the SG300 is the problem. Who knows, anyways..
debug1: Next authentication method: publickey
debug1: Trying private key: /share/MD0_DATA/XXX/.ssh/identity
debug1: Offering public key: /share/MD0_DATA/XXX/.ssh/id_rsa
debug1: Server accepts key: pkalg ssh-rsa blen 277
debug1: read PEM private key done: type RSA
debug1: Authentication succeeded (publickey).
Username:
Why is this?
Also, I notice after disabling Pubkey auth on the switch I am actually prompted for a login name twice?
Login: user1
Username: user1
Password: xxx
With pubkey enabled and my key passed and authorized, I am only seeing 1 login. Perhaps the key is getting me by the first login, but not the second?
Answer (Tom Watts):
Hi Michael, I believe there is 1 step you have missed.
You need to remove the local log in for the SSH.
I have generated a PPK file using PuttyGen then loaded the public RSA to the switch then defined my user name as tom. Once I removed the local log in and changed it to "none" I was able to enter my SSH user and then bypass any prompts. However I did have to type enable to get to exec mode.
login as: tom
Authenticating with public key "rsa-key-20130218"
SG300-28P>en
SG300-28P#
Here is my config, please notice the bold section.
SG300-28P#show run
config-file-header
SG300-28P
v1.2.7.76 / R750_NIK_1_2_584_002
CLI v1.0
file SSD indicator encrypted
ssd-control-start
ssd config
ssd file passphrase control unrestricted
no ssd file integrity control
ssd-control-end cb0a3fdb1f3a1af4e4430033719968c0
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
hostname SG300-28P
aaa authentication enable SSH none
aaa authentication login SSH none
line ssh
login authentication SSH
enable authentication SSH
password da39a3ee5e6b4b0d3255bfef95601890afd80709 encrypted
exit
ip ssh server
ip ssh pubkey-auth
crypto key pubkey-chain ssh
user-key tom rsa
key-string row AAAAB3NzaC1yc2EAAAABJQAAAIEAiyXSPjNqiE6d
key-string row afuUPRxWPKOwTWiDP3vLvEaHtuIOfeQdxJbBgjgb
key-string row vk/BIq/icKMjOUWBKytHBon3InbxGFjcuIftWkms
key-string row qffX7jALswFK4DZIbWhopDs+368oxd+r
key-string row 8pjIpR5UMB+0beM3UjAC+cO4CGlW7OVZr727C2Jh
key-string row YKbh/6s= rsa-key-20130218
exit
exit
snmp-server server
snmp-server community tom12345 rw view DefaultSuper
snmp-server group v1defaultGroup v3 auth notify Default read Default write Default
clock timezone " " -5
clock source sntp
clock dhcp timezone
interface vlan 1
ip address 192.168.100.98 255.255.255.0
no ip address dhcp
ip default-gateway 192.168.100.1
snmp-server set  rlAutomaticClockSetFromPCEnabled rlAutomaticClockSetFromPCEnabled true
SG300-28P#
Here is my public key I had used
ssh-rsa AAAAB3NzaC1yc2EAAAABJQAAAIEAiyXSPjNqiE6dafuUPRxWPKOwTWiDP3vLvEaHtuIOfeQdxJbBgjgbvk/BIq/icKMjOUWBKytHBon3InbxGFjcuIftWkmsqffX7jALswFK4DZIbWhopDs+368oxd+r8pjIpR5UMB+0beM3UjAC+cO4CGlW7OVZr727C2JhYKbh/6s= rsa-key-20130218
You could see this post here  https://supportforums.cisco.com/message/3859331#3859331
Credits´s to Tom Watts for this usefull information
