Tom Watts
This is a document for the SX300 series SNMP object names. There are 2 lists. mibs_1_1_2_0 which are all of the object names supported on the 1.1.2.0 firmware. The second list is mibs_1_2_7_76 which are the object names supported on the 1.2.7.76 firmware.
Additionally, I will list the object names that are different between the versions. The 1.2.7.76 software is not missing anything from the previous 1.1.2.0 release. However, the following below is what the 1.2.7.76 software contains that the 1.1.2.0 does not.
      rlAAAAccountingDot1xMethod
      rlAAAAccountingMngMethod
      rlAutoSmartBusy
      rlBrgMacHashFunction
      rlBrgMacHashFunctionAfterReset
      rlCascadeAfterResetTable
      rlCascadeTable
      rlEeeEnable
      rlEeePortLldpLocalTable
      rlEeePortLldpRemoteTable
      rlEeePortLldpTable
      rlEeePortTable
      rlIgmpSnoopMulticastTvTable
      rlIpArpInspectClearCountersAction
      rlIpArpInspectEnable
      rlIpArpInspectEnableVlanTable
      rlIpArpInspectListTable
      rlIpArpInspectLogInterval
      rlIpArpInspectMibVersion
      rlIpArpInspectTrustedPortTable
      rlIpArpInspectValidation
      rlIpDhcpOpt82RxOnUntrustedEnable
      rlIpDhcpSnoopClearAction
      rlIpDhcpSnoopCurrentEntiresNumber
      rlIpDhcpSnoopEnable
      rlIpDhcpSnoopEnableVlanTable
      rlIpDhcpSnoopFileEnable
      rlIpDhcpSnoopFileUpdateTime
      rlIpDhcpSnoopMibVersion
      rlIpDhcpSnoopStaticTable
      rlIpDhcpSnoopTable
      rlIpDhcpSnoopTrustedPortTable
      rlIpDhcpSnoopVerifyMacAddress
      rlIpSourceGuardEnable
      rlIpSourceGuardMibVersion
      rlIpSourceGuardPermittedRuleCounterTable
      rlIpSourceGuardPortTable
      rlIpSourceGuardRetryTime
      rlIpSourceGuardRetryToInsert
      rlIpSourceGuardTable
      rlMaxIpDhcpSnoopingEntries
      rlMaxIpDhcpSnoopingEntriesAfterReset
      rlPhdForceMasterUnit
      rlPhdNumberOfUnits
      rlPhdStackFixedUnit
      rlPhdStackFixedUnitLocation
      rlPhdStackOrderBottomUnit
      rlPhdStackOrderPermutation
      rlPhdStackOrderTopUnit
      rlPhdStackReloadUnit
      rlPhdStackTable
      rlPortVlanTriplePlayMulticastTvTable
     rlSmartPortsCondenseMode
      rlSshClientAuthenticationMethod
      rlSshClientDeleteSelfKey
      rlSshClientImportExportSelfKeyTable
      rlSshClientPassword
      rlSshClientPasswordChangeTable
      rlSshClientRegenerateSelfKey
      rlSshClientSaveImportedKeysWithPassphrase
      rlSshClientSavePassphraseForExportingKeys
      rlSshClientSelfPublicKeyFingerprintTable
      rlSshClientSelfPublicKeyTable
      rlSshClientUserName
      rlStackActiveUnitIdTable
      rlStackHybridTable
      rlStackUnitMode
      rlStackUnitModeAfterReset
      rlTimeBasedPortTable
      rlTimeBasedPortVersion
      rsArpNumOfEntries
      vlanTriplePlayMulticastTvTable
      vlanTriplePlayTable
