TransceiversFeatures and Related Links
MFEFX1 100 Base-FX Mini-GBIC SFP Transceiver
100Mbps Fiber Optic connectivity for Short Reach Applications
MFELX1 100 Base-LX Mini-GBIC SFP Transceiver
100Mbps Fiber Optic connectivity for Intermediate Reach Applications
MGBLH1 Gigabit Ethernet LH Mini-GBIC SFP Transceiver
An easy-to-install Mini-GBIC (Gigabit Interface Converter) module that provides a easy way to add Gigabit functionality to a Cisco Small Business switch. Achieves distances of 500 meters to 40 kilometers depending on the fiber used.
MGBSX1 Gigabit Ethernet LH Mini-GBIC SFP Transceiver
An easy-to-install Mini-GBIC (Gigabit Interface Converter) module that provides a easy way to add Gigabit functionality to a Cisco Small Business switch. Achieves distances of 220 or 550 meters depending on the fiber used.
MGBT1 Gigabit Ethernet 1000 Base-T Mini-GBIC SFP Transceiver
An easy-to-install Mini-GBIC (Gigabit Interface Converter) module that provides a easy way to add Gigabit functionality to a Cisco Small Business switch. Maximum distance is 100 meters.
Power SupplyFeatures and Related Links
RPS1000 380W Redundant Power Supply Unit
Highlights
• Provides transparent power backup for select Cisco Small Business products
• Helps ensure uninterrupted operation and protection against device power supply failures
• Increases system availability of converged voice, video, and data networks
chrcoope
The links in this are broken. the quick start guide link works, as does the RPS but all other SFP links are broken.
