on 09-16-2011 09:37 AM
Region Packs provide localization parameters (telephony parameters, dial plans, audio files, time zone lists, etc.) so that the UC320W may operate properly in countries/regions beyond those embedded in the Software Release. Region Pack support requires UC320W firmware version 2.1.1(7) or higher. Firmware release 2.1.4(3) or higher should be installed prior to installing Region packs.
Region packs do not change the language within the UC320W Configuration Utility text itself. As a reminder you can change the UC320W Configuration Utility language to one of the supported languages by setting your browser's language preferences. You can also select one of the supported languages by adding: /wizard/setupwizard.html?m=1 to the end of the URL that you use to access the UC320W. For example, if you normally access the GUI by:
you can use:
http://192.168.10.1/wizard/setupwizard.html?m=1
| Locale | Region | Supported UC320W Firmware | Release Notes | Comments |
| Australia | Australia_x3_v1 | 2.2+ | Adds support for FXO 2 digit star codes to the dial plan. | |
| Canada (English) | Canada(English)_x2_v2 | 2.2+ | Updates Class of Restrictions to separate toll free (18xx) from long distance. | English only AA and Voicemail prompts. |
| Canada (English/French) | Canada(English/French)_x2_v2 | 2.2+ | Updates Class of Restrictions to separate toll free (18xx) from long distance. | English is the primary language, French is secondary. |
| Canada (Francaise) | Canada (Francaise) _x2_v2 | 2.2+ | Updates Class of Restrictions to separate toll free (18xx) from long distance. | French only AA and Voicemail prompts. |
| Canada (Francaise/Anglais) | Canada (Francaise/Anglais)_x2_v2 | 2.2+ | Updates Class of Restrictions to separate toll free (18xx) from long distance. | French is the primary language, English is secondary. |
| Dominican Republic | República Dominicana_x3_v2 | 2.2+ | Support dominican republic dialing for prepaid call | Add support for dominican republic dialing for prepaid call |
| Österreich | Österreich_x3_v3 | 2.2+ | Allow user to input area code 720 | Allow user to input area code 720 when region is set to Österreich |
| Spain | Espana_x2_v3 | 2.2+ | Allow carrier cut through calls (10xx + address) to work. | |
| Germany | Deutschland_v3.rp | 2.1.x only | The Deutschland_v3.rp contains important fixes for anyone with a SIP trunk:
| Hungary | Magyar_x2_v5 | 2.2+ | Updates the Hungary Region dialplan | |
| Italy | Italy_v2 | 2.1.x only | Updates the built in Italy Region dialplan | Adds support for addresses: 117, 18x, 19x, beginning with 80 and are 9 digits in length. |
| Italy | Italy_x3_v1 | 2.2+ | Updates the built in Italy Region dialplan | Adds support to older mobile numbers 3xx xxxxxx (9 digits). |
| .Ireland | Ireland_x2_v3 | 2.2+ | Updates addresses begining with 023 043 052 064 to support 7 additional digits. | |
| New Zealand | New Zealand v4 | 2.1.x only | Updates the built in New Zealand Region dialplan | Adds support for addresses beginning with 0282 |
| Switzerland | Schweiz (Deutsch) | 2.1.x, 2.2.x | Switzerland | German language |
| Switzerland | Suisse (française) | 2.1.x, 2.2.x | Switzerland | French language |
| Switzerland | Svizzera (Italiano) | 2.1.x, 2.2.x | Switzerland | Italian language |
| Switzerland | Switzerland (English) | 2.1.x, 2.2.x | Switzerland | English language |
| United States | United States_x2_v4 | 2.2+ | Updates Class of Restrictions to separate toll free (18xx) from long distance. |
Installation Instructions:
NOTE: The list of region packs presented by the Cloud may change depending upon the version of current running UC320W firmware.
When posting a question or problem to the community or making a call to the Small Business Support Center it is important to mention that you have installed a region pack.
Hi Alberto
I believe we have all been quite patient on waiting for a response. Is there any news on the region pack for South Africa? I see that the UC500 is being launched in SA now, has there been any development in the UC320 for the region?
Many Thanks
David
David,
Region Pack development is on hold and there is no target date yet.
Nitin.
I wonder if this product can work in BOLIVIA (Latin America), and if can, what Region Pack I need to use for config.
Hi, any info on what the Region pack Italy_x3_v1 i see on the cloud is? Couldnt find the description on this page... thanks!
Hi Stefano,
This region pack is to to support older mobile numbers 3xx xxxxxx in Italy.
Thanks!
Is thier a plan to make UC320 open? so that we can do our own pack?
Or any plan to make a region pack for Africa? or Mauritius?
Hello, we need Turkey Region Pack, we want sell this product on Turkey. UC320W very usually but doesnt have Turkey Region Pack.
Hi Ertugrul,
Sorry, we currently don't have plan to support Turkey region.
Best regards,
Wendy
I'm still waiting for a region pack for the Netherlands. Are there any plans. In not, is there a other way to use the UC320 in the netherlands?
Hi Vincent,
We don't have plan to implement Netherlands. There is no other way to use the UC320W in the Netherlands.
Best regards,
Wendy
Why does Cisco sell the UC320W to dealers in the Netherlands through its official distributors if there is no way to use it?
Kind regards,
Alex
Dear Alexis;
First of all apologizes for any inconvenience. Some distributors are EU wide and wrongly position the product. You have the right to return the product at zero cost to the distributor.
Regards;
Alberto
Dear Wendy and Alberto,
Why don't you delevop Turkish region pack, don't you thing it will be profitable ? This product targets SMB and Turkey is the biggest emerging market in the region. You cannot compete using UC540/560 or CUCMBE with local pbx vendors in SMB section.
Cumhur
Dear Alberto,
Returning the product is one thing.
We have customers that bought the product and have been waiting for almost a year to get the functionality they paid for. Having to bring them this message brings reputational damage to the brand and the dealers.
Alexis
