on 09-16-2011 09:37 AM
Region Packs provide localization parameters (telephony parameters, dial plans, audio files, time zone lists, etc.) so that the UC320W may operate properly in countries/regions beyond those embedded in the Software Release. Region Pack support requires UC320W firmware version 2.1.1(7) or higher. Firmware release 2.1.4(3) or higher should be installed prior to installing Region packs.
Region packs do not change the language within the UC320W Configuration Utility text itself. As a reminder you can change the UC320W Configuration Utility language to one of the supported languages by setting your browser's language preferences. You can also select one of the supported languages by adding: /wizard/setupwizard.html?m=1 to the end of the URL that you use to access the UC320W. For example, if you normally access the GUI by:
you can use:
http://192.168.10.1/wizard/setupwizard.html?m=1
| Locale | Region | Supported UC320W Firmware | Release Notes | Comments |
| Australia | Australia_x3_v1 | 2.2+ | Adds support for FXO 2 digit star codes to the dial plan. | |
| Canada (English) | Canada(English)_x2_v2 | 2.2+ | Updates Class of Restrictions to separate toll free (18xx) from long distance. | English only AA and Voicemail prompts. |
| Canada (English/French) | Canada(English/French)_x2_v2 | 2.2+ | Updates Class of Restrictions to separate toll free (18xx) from long distance. | English is the primary language, French is secondary. |
| Canada (Francaise) | Canada (Francaise) _x2_v2 | 2.2+ | Updates Class of Restrictions to separate toll free (18xx) from long distance. | French only AA and Voicemail prompts. |
| Canada (Francaise/Anglais) | Canada (Francaise/Anglais)_x2_v2 | 2.2+ | Updates Class of Restrictions to separate toll free (18xx) from long distance. | French is the primary language, English is secondary. |
| Dominican Republic | República Dominicana_x3_v2 | 2.2+ | Support dominican republic dialing for prepaid call | Add support for dominican republic dialing for prepaid call |
| Österreich | Österreich_x3_v3 | 2.2+ | Allow user to input area code 720 | Allow user to input area code 720 when region is set to Österreich |
| Spain | Espana_x2_v3 | 2.2+ | Allow carrier cut through calls (10xx + address) to work. | |
| Germany | Deutschland_v3.rp | 2.1.x only | The Deutschland_v3.rp contains important fixes for anyone with a SIP trunk:
| Hungary | Magyar_x2_v5 | 2.2+ | Updates the Hungary Region dialplan | |
| Italy | Italy_v2 | 2.1.x only | Updates the built in Italy Region dialplan | Adds support for addresses: 117, 18x, 19x, beginning with 80 and are 9 digits in length. |
| Italy | Italy_x3_v1 | 2.2+ | Updates the built in Italy Region dialplan | Adds support to older mobile numbers 3xx xxxxxx (9 digits). |
| .Ireland | Ireland_x2_v3 | 2.2+ | Updates addresses begining with 023 043 052 064 to support 7 additional digits. | |
| New Zealand | New Zealand v4 | 2.1.x only | Updates the built in New Zealand Region dialplan | Adds support for addresses beginning with 0282 |
| Switzerland | Schweiz (Deutsch) | 2.1.x, 2.2.x | Switzerland | German language |
| Switzerland | Suisse (française) | 2.1.x, 2.2.x | Switzerland | French language |
| Switzerland | Svizzera (Italiano) | 2.1.x, 2.2.x | Switzerland | Italian language |
| Switzerland | Switzerland (English) | 2.1.x, 2.2.x | Switzerland | English language |
| United States | United States_x2_v4 | 2.2+ | Updates Class of Restrictions to separate toll free (18xx) from long distance. |
Installation Instructions:
NOTE: The list of region packs presented by the Cloud may change depending upon the version of current running UC320W firmware.
When posting a question or problem to the community or making a call to the Small Business Support Center it is important to mention that you have installed a region pack.
Hi Alexis;
Thanks for your email. The device has never been supported on Netherlands. Unfortunately the only option is to return the product as this is an error of the distributor.
I understand you would like to serve your customers with this product but unfortunately it is not available and there are no plans to make it available.
Regards;
Alberto
Hi, any info on what the Region pack Italy_x3_v2 i see on the cloud is? On this page there is just description of Italy_x3_v1, but couldnt find the description of _v2... thanks!
Hi Stefano,
The region pack Italy_x3_v2 is to support Italy 3xxxx. mobile numbers.
Best regards,
Wendy
Hello ,
Does it possible to prepare locale pack ? If it is possible how can we prepare ? We want to do it ourselves.
Hi Gorsel,
We do not support partners/customers developing their own region packs. There are no plans to provide an API to do so. If there are problems with a UC320W running within a supported region, we will provide additional region pack updates if the fix can be addressed via a region pack.
Best regards,
Wendy
Are there any news about region pack for Poland?
Marek
Hi Marek,
We currently don't have plan to support Poland region.
Best regards,
Wendy
Are tthere any plans to supoort Russia or Belarus?
Best regards,
Alexander
Hi Alexander,
Currently we don't have plan to implement Russia or Belarus regions.
Best regards,
Wendy
I think the UC320 is a big faillure! There are a few coutries where it works.. Crazy that you can't create your own dialplans...
There's potential problem with the Portuguese region pack, since the international country code seems to be +35, instead of +351
This generates problems configuring some sip accounts.
Can anyone please check if this is accurate?
can I fix this myself?
Can you please point me to the right direction on where I can get a region pack for Argentina? Why the dialing plans are not editable?
UC320 does not support Region pack for argentina.Dial plan of uc320 is non-editable by design.
Nima
Hi Alberto:
I understand that the UC320W does not support many countries such as Turkey and Lebanon. What about the SPA8800? As a replacement for UC320W does it support Turkey and Lebanon?
I recently moved to Monaco and I can not use the French dial plan as the countrycode is +377. Apart from that it´s the same! Could you please provide information on a possible pack or solution for the local calls to function?
