smallbusiness
Community Manager
Community Manager
Article ID:5311
WAP150 Indoor Wall Mounting
Table of Contents
Objective
The WAP150 Access Point can be mounted to a wall in order to ensure optimal performance.
The objective of this document is to demonstrate the mounting options and features of the WAP150.
For a full length demonstration of WAP150 Indoor Mounting Options, please view the video below:
Applicable Devices
  • WAP150
Indoor Mounting
Materials Needed for Mounting
To Mount the WAP150 indoors, you will need the following materials from the mounting kits:
  • 2 - Screws (0.26 in / 0.69 in)
  • 2 - Anchors (0.32 in / 0.87 in)
Drilling Holes for Anchors
First, use a ruler to determine the mounting hole positions. The holes should be 3-5/8 inches apart from each other. Mark and drill the holes accordingly.
In this demonstration, we used a 5/32 inch drill bit to drill the holes.
Inserting Anchors and Screws into Wall
Insert the 0.32/0.87 inch anchors into the drilled holes and then screw the .26/.69 inch screws into each anchor.
Tighten the screws in place, leaving room to mount the WAP150 onto the screws.
Mounting WAP150 to Wall
Lastly, align the back of the WAP150 with the screws and position the WAP150 to lock the device in place.
Conclusion
This concludes our tutorial on indoor mounting options for the WAP150. To provide consistent coverage for an indoor location, the WAP150 can be fixed onto a wall within the area. With the appropriate tools and mounting kit, either option can be quickly and easily established.
Khaledbwz
How to mount it on the ceiling?
