Jane Faraola
When you set up your Cisco WebEx Telepresence subscriptions (see WebEx Telepresence portal: Approve your order), at the end of the process you are automatically taken to the Cisco WebEx Telepresence portal. The next time you use the WebEx Telepresence portal, you need to sign in. For your username, you use the email address that was entered for you (as the administrative contact or the billing contact) during the WebEx Telepresence order process. For your password, use the password you created during subscription setup (see WebEx Telepresence portal: Create your portal password).
When you sign in, you can choose to remain signed in for future visits.
1.       Go to https://myaccount.telepresence.webex.com.
2.       For your username, enter your administrative contact or billing contact email address.
3.       Enter your WebEx Telepresence portal password.
If you forget your password, click Forgot your password? and follow the onscreen instructions.
4.       (Optional) Check the Keep me signed in box to be signed in automatically when you visit the portal in the future.
5.       Click Sign in.
