Patrick Born
Configure a speed dial (SD) to an unused line key on a SPA525G IP phone.
This document describes 3 methods of configuring speed dials:
1. Using an unused line key
2. Using one of the SPA525Gs speed dial keys
3. Using a SPA932 attached to a SPA525G
Note: You can also define up to 8 speed dials without using line keys [see end of document]
Define a SD on a line key as follows:
Phone’s web-ui Voice > Phone tab > Line Key N:
Extension: Disabled                        Short Name: SDTest
Share Call Appearance: private
Extended Function: fnc=sd;sub=812144735876@$PROXY;ext=812144735876@$PROXY
Where:
fnc—function
sd—speed dial
sub—tag to assign the SUBSCRIBE URL
812144735876:
8—steering digit
1—long distance
214—area code
4735876—DID
$PROXY—$PROXY [literally type this in]
ext—extension to dial [DID with steering digit in this case (strictly speaking, extension of phone being monitored)]
Use this speed dial by pressing the associated line key.
The release note syntax: fnc=type;sub=stationname@$PROXY;ext=extension#@$PROXYvid=#
Where: vid=#—specifies the extension the sidecar key is associated with.  By default, it is Ext 1.
For example, if you have a registered Ext 2 with another proxy server, and you want to monitor other lines from that new account, you'll need to add "vid=2".  When Ext 2 registers, the SUBSCRIBE message is then sent.
Assign up to 8 regular speed dials without using Line Keys:
Phone’s web-ui > User tab > Speed Dial > Speed Dial N: 812144735876
Where:
N—speed dial 2 through 9
812144735876:
8—steering digit
1—long distance
214—area code
4735876—DID
Use a regular speed dial by pressing the number, example “2” and then pressing the Dial soft key on the phone.
Configuring SD on a SPA932 Attached to a SPA525G
The SPA932 is configured in the same way as the Extended Function of each line key.
  1. Navigate to the SPA525G's web-ui/admin/advanced
  2. Click Att Console
  3. Insert SD information using the extended function syntax described above in the line key section.
  4. Once the SPA525G reboots, the related LED on the SPA932 will be green.
  5. Press the LED/button and the SPA525G will go off-hook and dial the configured number
<end>
NathanBurkett1
Community Member
Is it possible to configure this so that calls can be transferred to the speed dials programmes into the spare line keys?
cw00dward
That would be cool.  I would also like to see a speed dial set up that isn't associated with the SIP server.  Cisco is awesome and the SPA525 is a really nice telephone phone for anyone.  The bluetooth is really fun too!
Mike171178
It is possible to send a DTMF with Speed Dial like *310#?
Dan Lukes
Yes. If there's call connected, the bXfer to destination is initiated instead. I'm unsure which firmware version introduced this behavior. But there may be issue if you are registered to more than one softswitch. Read  this comment for more.
