Default Configuration settings on the ESW 500 Series
The ESW 500 series switches ship with a default configuration that enables simplified installation and plug and play when connected into a Cisco Small
Business network such as SBCS. The default settings are as follows:
- Management VLAN is VLAN 1
- Management IP Address is obtained via DHCP by default. If the switch times out on a Dynamic Host Configuration Protocol (DHCP) response, it falls back to a static IP address 192.168.10.2 with subnet mask of 255.255.255.0.
- Voice VLAN is VLAN 100
- Cisco Discovery Protocol (CDP) is enabled on all ports
- Default Smartport roles are as below:
Slide 1 ESW500 Series SKU | Layer 2 switch ports | Uplink ports |
Desktop SmartPorts Role | Desktop + IP Phone SmartPorts Role | Switch SmartPorts Role |
ESW-520-24-K9 | e1 – e24 | NA | g1 – g4 |
ESW-520-24P-K9 | NA | e1 – e24 | g1 – g4 |
ESW-520-48-K9 | e1 – e48 | NA | g1 – g4 |
ESW-520-48P-K9 | NA | e1 – e48 | g1 – g4 |
ESW-540-24-K9 | g1 – g10, g13 – g22 | NA | g11 – g12, g23 – g24 |
ESW-540-24P-K9 | NA | g1 – g10, g13 – g22 | g11 – g12, g23 – g24 |
ESW-540-48-K9 | g1 – g22, g25 – g46 | NA | g23 – g24, g47 – g48 |
