Steven DiStefano
For 24U annd above SKUs, use the kit for the ISR 3825
There is some guidance provided at the website  below:
relionllc
Hi, I know it's obsolete and all, but for a UC520-8U, I need to get it rack mounted and the published part number (ACS-UC500RM-19=) is basically out of existence. I just need those long ears. If I remember correctly, isn't this chassis the same as another old ISR, like 1841 or something like that? Bottom line, is there another part number that I CAN still order that will rack mount this UC520-8U? It's the same as the uc540, too, no?
Thanks.
BRIAN SEKLECKI
Same question here! ~BAS
BRIAN SEKLECKI
The UCS520W and 1861 are basically the same chassis, 10.5" wide, so the rack ears should be shareable, if the screw holes line up.
 ACS-1861-RM-19
I'll let you know.
7 Years....
~BAS
BRIAN SEKLECKI
IT WORKS:
1861 rails are a perfect substitute.  And ACS-1861-RM-19 is still readily available on the market.
https://photos.google.com/share/AF1QipOR1oKo03F9qs67kny3T0QJ9KV904ZVvqjs6Jj7iXav6wTv0TfJxPR9Q5aJHH975g?key=dUdEOEJlbXNYNmpQWk1Ua1VwUmdzUF9mWU1fT1l3
https://plus.google.com/+BrianSeklecki/posts/7docb6ExRo5
~BAS
