Alberto Montilla
Don't know what you need or where to look?
Use this Document Map to locate everything SPA3xx and SPA5xxG IP Phone related.
For other Cisco Unified IP Phones, please check http://www.cisco.com
[toc:faq]
Datasheets
ProductPDF
SPA901Download
SPA921Download
SPA922Download
SPA941Download
SPA942Download
SPA962Download
SPA932Download
WIP310
Download
SPA301        Video DatasheetDownload
SPA303        Video DatasheetDownload
SPA501GDownload
SPA512GDownload
SPA502G
Download
SPA514GDownload
SPA504GDownload
SPA508GDownload
SPA509GDownload
SPA525G2          Video DatasheetDownload
SPA500SDownload
SPA500DSDownload
CP-521G/SG and CP-524G/SGDownload
Phone User Guides
SPA3xx IP Phone User Guide
(Localized) SPA300 IP Phone Quick Start Guide
(Localized) SPA300 IP Phone User Guides
SPA5xx IP Phone User Guide
Small Business Pro IP Phone SPA50X Quick Start Guide
Small Business Pro IP Phone SPA50X User Guide (for SIP deployment)
SPA5xxG User Guides (Localized)
Small Business Pro IP Phone SPA50X User Guide (for SPCP - UC500 deployment)
(Localized) SPA525G Quick Start Guides
Small Business Pro IP Phone SPA525G User Guide ( for SIP deployment)
Small Business Pro IP Phone SPA525G User Guide (For SPCP - UC500 deployment)
Attendant Console User Guides
Cisco Small Business Pro SPA500S Attendant Console Quick Start Guide
Cisco Small Business Pro SPA500DS Attendant Console Quick Start Guide
SPA9xx IP Phone User Guide
Small Business IP Phones SPA9XX Quick Reference Guide
(Localized) SPA9XX Quick Setup Guides
Small Business IP Phones SPA9XX User Guide
WIP310 & 52xSG IP Phone User Guides
Cisco WIP310 Wireless-G IP Phone User Guide
Cisco WIP310 Wireless-G IP Phone Quick Installation Guide(Localized)
Cisco Unified IP Phone 521G and 524G Quick Reference Guide
Cisco Unified IP Phone 521G and 524G User Guide
Cisco Unified IP Phone 521SG and 524SG Quick Reference Guide
Cisco Unified IP Phone 521SG and 524SG User Guide
Phone Administration Guides
SPA3xx, 5xx, and WIP310 IP Phone Administration Guide
SPA9X2, SPA525G and WIP310 IP Phone Administration Guide
Phone Application Notes
Asterisk
Asterisk Collateral[misc. documentation]
Broadsoft
Broadsoft Collateral[CPE kits and misc. documentation]
Miscellaneous
SPA525G2 Call Recording to USB Device
SPA500 Skype For SIP interoperability app note
Configuring Redundant SIP Proxies
Configuring Cisco SRST with SPA5xx IP phones
Configuring SPA5xxG Programmable SoftKey (PSK)
Screen-scrape / Screen-dump of SPA50x and SPA30x
Call Rtn / lcr / Miss Missed call return popup and related softkeys
Configuring LDAP directory search on SPA9X2 SIP IP Phones
Security in IP Telephony - Activating SIP over TLS on SPA Voice Products
SPA9X2 Photo Album display
SPA9xx Phone: How to Transfer Calls
Changing background display on SPA9X2 phones
Configuring WIP310 Wireless-G IP Phone with the SPA9000 Voice System
SPA301 & SPA501 Interactive Voice Response (IVR) Menu Options
SPA525G2 differences to SPA525G
SPA500S Paper label template
SPA501G Paper label template
SPA509G Paper label template
XML Services for SPA5xxG phones
XML Services Collateral
Other Installation and Configuration documents
Push-to-talk: multicast between phones
Generating a sample configuration file for SPA Voice products
Configure SD [Speed Dial] on unused SPA9x2 line key
Configure SD [Speed Dial] on the SPA525G IP Phone
Field Notice: spacroot.crt Deprecated
Instructions for creating signed SSL Certificates for SPA Voice products[Certificate Signing Request (CSR)]
SPA Certificate Authority (CA) List
SPA-Voice Debug - Reboot Reason List
Cisco IP Telephony Devices Provisioning Guide
Installing the Wall-Mount bracket for Cisco Unified IP Phones 521(S)G and 524(S)G
Provisioning: Disabling Automatic Provisioning by the SPA9000
SPA525G Screen Saver: Displaying photographs and graphics
SPA525G Wallpaper: Displaying photographs and graphics
Upgrading a Device Using a TFTP Server and an URL
Configuring Ring Tones for Inbound Calls
SPA50xG Quick Start Guide (Localized)
SPA525G Quick Start Guide (Localized)
SPA3xx / SPA5xx Auto Answer Page: PTT, intercom, and paging interruptions
SPA and WIP IP Phone Headset Jack Details
SPC: Creating a SPA3xx or SPA5xx Configuration File
SPA3xx/5xx Conference Bridge URL
Configuring a Logo on SPA303 and SPA50x IP Phones
SPA303 & SPA50xG IP Phone Line Navigation
Configuring SIP PUBLISH on SPA30x and SPA5xxG IP Phones
Extracting SPA Phone Configuration with spacfg.xml
Configuring Resync_At_HHmm_ Resync at time of day feature
Determining the hardware version of a SPA525 IP Phone
Explaining Dial Plans
SPA phone fast busy, dial plan timer P and dial tone script
Troubleshooting
Troubleshooting a SPA932 Attendant Console [Side car]
Saving a Phone's HTML Configuration
Extracting / pushing a Phone's XML
Debug and syslog Messages from the SPA3xx, SPA5xxG, SPA9xx, & WIP310 IP Phones
Using the slogsrv.exe Utility
SPA5xx / WIP310 MWI 410 Subscription is Already Terminated
SPA9000 Setup Wizard Not discovering SPA IP phones
SPA5xx IP phone will not hang up when call is ended by remote party
SPA5xxG IP Phone Audio Quality
SPA30x and Certificate Authority (CA)
SPA525 reboots continuously / is "bricked"
SPA525 upgrade fail code 101
SPA525G2 "Upgrade failed: upgrade not allowed, version constraint" or "Upgrade failed: upgrade to less than rev not allowed"
SPA3xx & SPA5xx Periodic Reboot After a Resync
missed-call-summary when SIP-B and CFWD Notify Serv are enabled for wrong call-control
which parameters if changed, cause a phone to reboot?
SPA Phone MOS and status information
SPA303 / SPA50x will not stop playing ring-back with 7.4.7
SPA Phones Contacting Unknown/Foreign IP Addresses
Factory defaulting a SPA IP Phone, where is the factory default menu option?
Installing and Using Wireshark for Capturing Network Traffic
Call states of SPA IP Phones and ATA devices (NewCallState syslog message)
Tutorials
SPA300 IP Phone Video Datasheet: YouTube [2.5 minutes]
SPA525G2 IP Phone Video Datasheet: YouTube [2.5 minutes]
SPA525G  Phone Interactive Tutorial
SPA500 Series Phone Interactive Tutorial
SPA5xx IP Phone Provisioning Options Tutorial: YouTube [4.5 minutes]
SPA5xx IP Phone Plug and Play: YouTube [3 minutes]
SPA5xx IP Phone DHCP OPTIONS [66, 159, 160, 150]: YouTube [4.5 minutes]
SPA5xx IP Phone Remote Customization (RC): YouTube [4 minutes]
SPA5xx IP Phone Boot Process Details: YouTube [8 minutes]
Cisco WBPN Wireless-N Bridge for SPA Phones [YouTube and documents]
Licensing Information
Open Source License Notices for the SPA525G
Related Products Configuration Guides
SPA9000 Voice System Configuration Guides
SPA ATA and Gateways Configuration Guides
Miscellaneous
SPA5xx IP Phone 7.x Firmware Update Information
SPA Phone Firmware, Localization, & Tools
WIP310 Protective cover / case from zCover
SPA Phone Power Budget with ESW520-24P PoE switch
Product Warranty
SPA 525G2 Mobile Link - Bluetooth Compatibility assessment
2.5mm to RJ-9 / RJ-22 Headset adaptor cable for SPA phones
USB drives tested working with SPA525G and SPA525G2 IP Phones
Document Map Contains links to everything related to SPA phones
xtinehanley
Thank you for posting this. It's been a tremendous resource!
Dan Lukes
Unfortunately, this document is unmaintained by author and become obsolete.
References to Small Business Pro IP Phone SPA50X User Guide (for SIP deployment), Small Business Pro IP Phone SPA50X User Guide (for SPCP - UC500 deployment), Small Business Pro IP Phone SPA525G User Guide ( for SIP deployment), Small Business Pro IP Phone SPA525G User Guide (For SPCP - UC500 deployment), Cisco Unified IP Phone 521G and 524G Quick Reference Guide and others including very important base document SPA3xx, 5xx, and WIP310 IP Phone Administration Guide are referring to non-existent destinations.
This list of documents has been maintained by community in the previous CSC system, but with this new one framework such kind of community cooperation is no longer welcomed by Cisco. Thus the document list can't be updated ...
That's life. Anyone needs to found documentation by self ...
Ask Google for all the things related to Cisco SMB. It's far better source of information that Cisco's own system.
