Alberto Montilla
Tested  by: David Liao, Cisco
UC320W   FW release: 2.0.5(3)
  • Provider:  Generic SIP Provider
  • Description: Cbeyond
  • Proxy: sipconnect-fca-alt0.cbeyond.net
  • Registration:  Checked (Client-server SIP trunk, registration  required)
  • Outbound   Proxy: sip-proxy-fca-alt0.cbeyond.net
  • Call   Capacity: <As  indicated by the ITSP in your  contract>
  • Prefix  # w/"+1" : Check (uses US international numbering  plan)
  • Company  Name:  <Your company  name> (this will appear  as the  Display Name field on SIP  messaging)
  • Account  ID:  <The  main DID number given by the ITSP  (e.g.  678397zzzz)>
  • SIP   domain  name: <Your company local domain name> Optional
  • Authentication ID: <Same as the Account ID>
  • Password:  <As indicated by the ITSP>
  • SRV  Recorded   Lookup: Uncheck
  • SRV Auto   Prefix:  Uncheck
  • NAT Mapping: Uncheck (ITSP provides SBC/Outbound proxy)
        Systemwide parameters
  • Codec: G711u
  • Outbound  FAX:  PassThrough
     Other requirements
  • WAN  network: Must use static IP address and fill in all information  (default gateway and DNS)
Known Issues:
     * PSTN phone  did not disconnect  when extension phone init disconnection.
jwaskewics
David,
Thanks for the post.  can you elaborate on "
Known Issues:
     * PSTN phone  did not disconnect  when extension phone init disconnection."
Is this fixed?  Is this a Cisco issue?
John
techiegzz
I tried the above configuration and it did not work so I tried other configurations based on the settings in my CBeyond (former Aretta account) as follows and it successfully registered and passed calls back and forth even though I have dynamic public IP. Perhaps the difference between this setup and the one above is that SIP CBeyond my account was originally setup when CBeyond was Aretta Communications and the URL has always been and still remains sip.aretta.net which may be why this worked for me but I don't know if the above settings is what newer Cbeyond customers who signed up directly with CBeyond after they acquired Aretta Communications. Pick what works in your case, I guess.;
  • Description: Name the trunk for your own reference
  • Proxy: sip.aretta.net
  • Outbound Proxy: sip.aretta.net
  • Call Capacity: <As indicated by CBeyond in your contract>
  • Account ID: <The username provided to you by CBeyond>
  • Password: <Password or Secret as indicated by the CBeyond>
  • Codec: G711u
